[GeoNetwork-devel] Detect a bug in inspire template
I found a bug in inspire template.
It actually has this section:
<gmd:alternateTitle gco:nilReason=“missing”/>
But it is wrong.
I don’t know how, but if it is filled with something it generate an error when write to DB.
I try to create a new MTD using inspire iso 19139 for services template.It is create, but if I try to change something I have an error.
I notice that uncheck the autofill option the error not happear but (obviously) the changes are not commited to the DB.
After some tests.
I discovered the problem is due to the
alternateTitle value.
It actually in the template inspire for services is defined like this:
because in every other tags was used another sintax I try to change to this sintax:
<gmd:alternateTitle gco:nilReason=“missing”>
gco:CharacterString/
</gmd:alternateTitle>
But the error there is again.
Finally I found that removing the alternateTitle from the metadata schema it
work without error.
Please notice I’m using IBM-DB2.
Perhaps there is some problem due even to this DBMS.I try with
mckoy but seem with it the error seem not happened.
Andrea Peri.
Andrea Peri
qwerty àèìòù
