In “index-fields.xsl” file of a schema’s folder, there is “index” and “store” attributes on each field.
But what is the difference between an “indexed” field and a “stored” field ?
Best Regards
Best Regards
these terms come from Lucene, the library used to do the indexing and retrieval.
Maybe this is helpful: http://wiki.apache.org/lucene-java/LuceneFAQ#What_is_the_different_between_Stored.2C_Tokenized.2C_Indexed.2C_and_Vector.3F
kind regards
Heikki Doeleman
On Wed, May 11, 2011 at 11:35 AM, Rudy Commenge <rudywi.devel@anonymised.com> wrote:
But what is the difference between an “indexed” field and a “stored” field ?Best Regards
Achieve unprecedented app performance and reliability
What every C/C++ and Fortran developer should know.
Learn how Intel has extended the reach of its next-generation tools
to help boost performance applications - inlcuding clusters.
http://p.sf.net/sfu/intel-dev2devmay
GeoNetwork-devel mailing list
Ok, but I don’t understand :
“Stored = as-is value stored in the Lucene index”
“Indexed = the text (…) is made searchable”
I thought “store something in lucene index” and “index something in lucene” were synonyms.
In fact, when I index something in lucene, it is searchable. Whereas, when I store something in lucene index, it is not searchable, right ? So, if I can’t search the data, why store it in lucene index ?
2011/5/11 heikki <tropicano@anonymised.com>
kind regards
Heikki DoelemanOn Wed, May 11, 2011 at 11:35 AM, Rudy Commenge <rudywi.devel@anonymised.com> wrote:
2011/5/11 Rudy Commenge <rudywi.devel@anonymised.com>:
Ok, but I don't understand :
"Stored = as-is value stored in the Lucene index"
"Indexed = the text (...) is made searchable"I thought "store something in lucene index" and "index something in lucene"
were synonyms.
can't search the data, why store it in lucene index ?
Because you could retrieve the field as-is (ie. not analyzed) from the
index (without the need to retrieve the original document, in our
case, from the xml doc stored in the db).
This could be used to speed up search results formatting (see
experimental search service
http://trac.osgeo.org/geonetwork/ticket/485).
Ciao.
Francois
retrieval.Maybe this is helpful:
http://wiki.apache.org/lucene-java/LuceneFAQ#What_is_the_different_between_Stored.2C_Tokenized.2C_Indexed.2C_and_Vector.3Fkind regards
wrote:Hi,
In "index-fields.xsl" file of a schema's folder, there is "index" and
"store" attributes on each field.
But what is the difference between an "indexed" field and a "stored"
field ?Best Regards
http://sourceforge.net/projects/geonetwork------------------------------------------------------------------------------
Ok, I begin to understand. Thx.
Where is the Lucene index ? Can I to explore its content ?
2011/5/11 Francois Prunayre <fx.prunayre@anonymised.com>
“Indexed = the text (…) is made searchable”I thought “store something in lucene index” and “index something in lucene”
were synonyms.
can’t search the data, why store it in lucene index ?Because you could retrieve the field as-is (ie. not analyzed) from the
case, from the xml doc stored in the db).This could be used to speed up search results formatting (see
http://trac.osgeo.org/geonetwork/ticket/485).Ciao.
Francois
2011/5/11 heikki <tropicano@anonymised.com…31…>
wrote:Hi,
field ?Best Regards
Rudy,
to explore the content of the Lucene index, use Luke : http://code.google.com/p/luke.
The index is by default in /web/geonetwork/WEB-INF/lucene/nonspatial.
Kind regards
Heikki Doeleman
On Thu, May 12, 2011 at 11:16 AM, Rudy Commenge <rudywi.devel@anonymised.com> wrote:
Where is the Lucene index ? Can I to explore its content ?2011/5/11 Francois Prunayre <fx.prunayre@anonymised.com>
were synonyms.
Francois
wrote:Hi,
field ?Best Regards
OK, it works very well. Thx.
I have created a new metadata schema, and I have indexed its fields using its “index-fields.xsl” file.
I have inserted some metadata with this schema.
Considering, I have a “myfield” field in this schema, how to use GeoNetwork search area or search service (xml.search) to retrieve data where value of “myfield” is equal to “myvalue” ?
2011/5/12 heikki <tropicano@anonymised.com>
Rudy,
Kind regards
Heikki DoelemanOn Thu, May 12, 2011 at 11:16 AM, Rudy Commenge <rudywi.devel@anonymised.com> wrote:
were synonyms.
Francois
wrote:Hi,
field ?Best Regards
