[GeoNetwork-devel] Draft proposal for a GN API
Hi all, with Paul, we tried to make a proposal for making a better API for GN. The main idea is when moving services from Jeeves to Spring MVC, we also document services and agree on a common structure for the API.
Here is a first draft for comment.
https://docs.google.com/document/d/1pj6D-hTPFtBDo3drcBF0tUqOVGnzu68VaAgHaMjWTZM/edit?usp=sharing
Looking forward your feedback.
Francois
Hi Francois-Xavier,
It looks good ! I put some comments / random thoughs inlined in the document ; the autogenerated api doc looks also nice, and will probably makes the development easier on the project (currently grepping the entry points / opening several files before being actually able to find the corresponding java class for a controller).
– Pierre
Dear All, during coming Bolsena codesprint, we would like to make significant progress on this topic. The target will be:
  • move services to Spring MVC following the API guideline
  • use the API in the Angular app
  • remove old services
  • add the guideline to the dev documentation
  • CFV for the API guideline
Let us know, if you’ve any comments on this.
Cheers.
Francois
2016-03-09 11:31 GMT+01:00 Pierre Mauduit <pierre.mauduit@anonymised.com>:
Hi Francois-Xavier,
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785111&iu=/4140
GeoNetwork-devel mailing list
– Pierre
