hi,
maybe that's a novice problem when working with eclipse, but i can't find a
solution. I implemented the geonetwork source code from git in eclipse with
maven...
to start geonetwork in eclipse i defined a tomcat server running the app.
that's working fine so far. but now i have a problem. when i edit the source
code and run the application again, the changes aren't detected. how can i
tell eclipse, that the source code has changed? i thought, eclipse is
compiling or building the project new when something changes. do i have to
build or compile the .java files in a certain way?
i already started the debug mode but it doesn't matter what i write in
source code, i always get the same response as if nothing has changed in
.java file.
thanks for your answer.
regards
View this message in context: http://osgeo-org.1560.n6.nabble.com/Editing-source-code-in-eclipse-but-changes-aren-t-detected-when-running-with-tomcat-tp5019803.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
