For GN 2.10.x, we have a XSL, update-fixed-info.xsl, in each schema that
applies when saving editor changes. In it, I want to handle
gmd:verticalElement (ISO19139), but I'm not able to match it. Even other
children of gmd:extent like gmd:temporalElement etc. do not match.
Even simplest of matching does not work:
<xsl:template match="gmd:verticalElement" />
<xsl:template match="gmd:temporalElement" />
<xsl:template match="gmd:geographicElement" />
None of the above works in update-fixed-info.xsl. I've handled many other
elements in this XSL without any issue. I checked that gmd:extent in fact
is matched but none of its child elements.
Is this by design or a bug. what is the way around if I want to handle
verticalElement or any other child of gmd:extent in this XSL?
On Mon, Dec 15, 2014 at 7:56 AM, Ameet Chaudhari
<ameet.chaudhari@anonymised.com> wrote:
First a quick stupid question, just in case: Are you trying with a
metadata that has this elements? You are only able to match it on a
metadata that contains the elements you want to match. It is a very
silly question and knowing your previous questions on the list I don't
think you will fail on something that simple, but we all have a bad
day sometimes...
elements in this XSL without any issue. I checked that gmd:extent in fact is
At the end of the xsl:template that matches (gmd:extent), do you call
again a template match recursively?
Something like:
<xsl:apply-templates select="*" />
gmd:verticalElement (ISO19139), but I’m not able to match it. Even other
silly question and knowing your previous questions on the list I don’t
day sometimes…
Oh I wish this should have been the case so atleast it would’ve solved quickly :), but not so :(. That’s the first thing I had checked. All the three children of gmd:extent are present in the metadata and also, the metadata xml is valid. Neither the elements are missing nor I’m opening the wrong metadata in editor.
<xsl:template match=“gmd:verticalElement” />
<xsl:template match=“gmd:temporalElement” />
<xsl:template match=“gmd:geographicElement” />
None of the above works in update-fixed-info.xsl. I’ve handled many other
Something like:
<xsl:apply-templates select=“*” />
Well far below is a template that matches like below, used for some namespace corrections.
<xsl:template match=“gmd:*”>
But this is there from long long time and anyway all other elements are matching properly. gmd:extent also matches at the same place ( If I replace the line for gmd:verticalElement with the one for gmd:extent, it matches! ).
Even then I will check by commenting that out and let you know.
Ameet
Thanks and Regards
Ameet
María.
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
