[GeoNetwork-devel] Embeddable Editor
I have a task to create a split similar to metadata.show and metadata.show.embedded for the editor. I want to create metadata.edit.embedded that allows the editor to be embedded into a page. In my case the client wants a dialog with a viewer which can switch to the editor with a press of the button.
My question is: Is the geonetwork community interested in having these changes so this use case can be implemented easier by other implementations.
A second option is accept the refactorings to metadata-edit.xsl that allow metadata-edit-embedded.xml to be implemented without too much code duplication. That way you would not be maintaining the metadata-edit-embedded.xsl but would be making it easy for third parties (like me) to add the functionality to new custom apps based on geonetwork.
Jesse
Maybe no changes are needed. I see there is already a metadata-edit-embedded.xsl for performing updates. Perhaps that is sufficient for my needs.
On Fri, Oct 29, 2010 at 9:25 AM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Jesse
Hi Jesse,
It could be great to improve the editor on that topic. I had a quick
look for that when working on the JS widgets [1]
2010/10/29 Jesse Eichar <jesse.eichar@anonymised.com>:
I don't think too much changes are required, at least :
* remove HTML page header to be embedded in an existing DOM element
* clean JS to update the appropriate element instead of document.body.
If you do some cleaning on the metadata-editor.js to move to Ext, I'm
interested.
Later, I could probably integrate that in the widget examples ?
Cheers.
Francois
[1] http://trac.osgeo.org/geonetwork/wiki/proposals/componentsBasedGui
wrote:
Jesse
Nokia and AT&T present the 2010 Calling All Innovators-North America contest
Create new apps & games for the Nokia N8 for consumers in U.S. and Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev
GeoNetwork-devel mailing list
