[GeoNetwork-devel] Error building GN3.0.0 (search.KeywordsSeracherTest)
Hello,
I am trying to build GN3.0.0 but am continually getting errors on
search.KeywordSearcherTest.
The error is:
/Run 1: KeywordSearcherTest.testKeywordSearchUsingId:538 expected:<1> but
was:<0>/
This repeats 6 times.
I am building on Ubuntu 14.04, Maven 3, OpenJDK 1.7.0_79.
Also, I am a bit confused as to how I add plugin schemas in GN 3.0.0. I am
referring to these pages as they are the only guidance I have found:
[1]
https://github.com/geonetwork/core-geonetwork/wiki/Proposal:-Schema-plugin-improvement
[2] https://github.com/geonetwork/core-geonetwork/pull/615
Can anyone provide any more detail here?
Byron
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-building-GN3-0-0-search-KeywordsSeracherTest-tp5204298.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hy Byron,
2015-05-06 2:57 GMT+02:00 ByronCinNZ <cochranes4@anonymised.com>:
Hello,
The error is:
was:<0>/
[1]
I started to update the doc on this. See
http://docs.titellus.net/geonetwork/en/customizing-application/implementing-a-schema-plugin.html#preparation - more work needed.
Depending on the plugin you want to load you may need to migrate it to GN3 with the Angular editor configuration and the changes described in the link you provided.
Francois
Byron
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-devel mailing list
