[GeoNetwork-devel] Error during install under jre1.6
i make some install tests with GeoNetwork 2.0.3. My configuration is:
Windows XP
JRE 1.6.0-b105 (pure installation, without some additional)
geonetwork-2.0.3-install.jar
Jetty/mckoi (but the same pb occurs using tomcat/mysql).
I run the geonetwork-2.0.3-install.jar and an error occurs during installation process (after step 4 while transfering files on the disk) : impossible to compile stylesheet" (see the file join to this message)
When i run the same geonetwork-2.0.3-install.jar under JRE1.5_07 the install works fine.
I have found a solution to solve the problem installing xalan.jar and serializer.jar V2.7.0 (from http://xml.apache.org) under the directory \lib\ext
Does anyone have encountered the same problem ?
Best regards
Laurent
