I am encountering an exception when attempting to fetch the groups for assigning privilege on a Geonetwork 2.1.x harvest type. This only occurs when I supply an account to use for the harvest. Do others encounter this? Is there a fix possibly in kernel.js or info-service.js to set up another header ‘Access-Control-Allow-Origin’ as many forums talk about this as the solution for this type of CORS error?
2014-07-30 11:04:14,024 INFO [jeeves.request] - ==========================================================
2014-07-30 11:04:14,024 INFO [jeeves.request] - HTML Request (from 138.7.36.134) : /geonetwork/srv/eng/xml.forward
2014-07-30 11:04:14,026 INFO [jeeves.service] - Dispatching : xml.forward
2014-07-30 11:04:14,718 ERROR [jeeves.service] - Exception when executing service
2014-07-30 11:04:14,718 ERROR [jeeves.service] - (C) Exc : BadXmlResponseEx :
Please wait...
Patientez s'il vous plaﴮ..
Bitte warten...
Un momento per favore...
JavaScript warning
To use GeoNetwork you need to enable JavaScript in your browser
2014-07-30 11:04:14,720 ERROR [jeeves.service] - Strack : BadXmlResponseEx :
Please wait...
Bitte warten...
JavaScript warning
at jeeves.utils.XmlRequest.doExecute(XmlRequest.java:357)
at jeeves.utils.XmlRequest.execute(XmlRequest.java:257)
at org.fao.geonet.services.main.Forward.authenticate(Forward.java:116)
at org.fao.geonet.services.main.Forward.exec(Forward.java:80)
at jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:231)
at jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:140)
at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:430)
at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:362)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:806)
at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:216)
at jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:125)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:646)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:322)
at jeeves.config.springutil.GeonetworkFilterSecurityInterceptor.invoke(GeonetworkFilterSecurityInterceptor.java:46)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.fao.geonet.kernel.security.PassthroughFilter.doFilter(PassthroughFilter.java:26)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:184)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:155)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:193)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
Kevin Gunn
Database Programmer and Instrument Technician
Australian Institute of Marine Science
Cape Ferguson Townsville Qld Aust. 4810
+61 7 47534305
The information contained within this transmission is for the use of the intended recipient only and may contain confidential and/or legally privileged material and/or material the subject of copyright and/or personal information and/or sensitive information that is subject to the Privacy Act 1988. Any review, re-transmission, disclosure, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you have received this email in error please notify the AIMS Privacy Officer on (07) 4753 4444 and delete all copies of this transmission together with any attachments.
