After checkout Git. I Build Solution "GeoNetWork opensource" in Netbeans but
with Error:
/Failed to execute goal
org.apache.maven.plugins:maven-surefire-plugin:2.18:test (default-test) on
project core: There are test failures.
Please refer to
E:\PROJECTS\2014\1.THUNGHIEMDIAPHUONG\3.Codes\Geonetworkv3.0\core\target\surefire-reports
for the individual test results.
-> [Help 1]
To see the full stack trace of the errors, re-run Maven with the -e switch.
Re-run Maven using the -X switch to enable full debug logging.
For more information about the errors and possible solutions, please read
the following articles:
[Help 1]
http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
After correcting the problems, you can resume the build with the command
mvn <goals> -rf :core/
Anybody help!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-when-build-Geonetwork-3-0-tp5207973.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
What command did you launch ?
You may can try : mvn clean install -DskipTests
On Thu, May 28, 2015 at 11:10 AM, kenzon <duc.humg@anonymised.com> wrote:
After checkout Git. I Build Solution “GeoNetWork opensource” in Netbeans but
with Error:
Please refer to
→ [Help 1]
[Help 1]
mvn -rf :core/
Anybody help!
GeoNetwork-devel mailing list
Florent Gravin
Camptocamp - Chambéry
0479444492
Yes, I do
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-when-build-Geonetwork-3-0-tp5207973p5207976.html
