[GeoNetwork-devel] Error when logging in NullPointer Exception
Hi guys. I recently built an installer for BlueNet MEST using Ant. I did not
make any changes to the code I downloaded from the source tree when I built
the installer. However, When i try logging in with the default admin/admin,
I get an error saying "Null pointer exception". Can anyone help me with
this? I would really appreciate it, thanks.
View this message in context: http://n2.nabble.com/Error-when-logging-in-NullPointer-Exception-tp4515984p4515984.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
hi,
it usually means you have no connection with the database.
You did actually use the installer to install the application, after having built it? I have sometimes made the mistake of “starting the application” from the bin directory in the source tree, instead of from a directory where I actually installed it …
Anything in the log files or in the console output that shows some error on starting the application ?
Kind regards
Heikki Doeleman
I get an error saying “Null pointer exception”. Can anyone help me with
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
GeoNetwork-devel mailing list
