Dear all,
I’m having an error while trying to insert a value for the source tag inside the Data Quality section ( ) using the web application.
I can enter a value for the parameter but it disappears after I click on ‘Save’. The value for this tag only is written if I write the value and just after click on ‘Save and Close’. I mean introducing this value is the last thing I must do before saving if I want to conserve the value.
I’m using the McKoi local database and I test that issue on two different installations and the error remains the same.
Thank you,
Victor
Víctor Centella Fuster
Prodevelop, Integración de tecnologías
http://www.prodevelop.es
Servei d’Informàtica
Conselleria de Territori i Habitatge
Francesc Cubells 7, 46011 València
Tel.: 96 197 3942
Email: asistenciagis1_ctv@anonymised.com
