[GeoNetwork-devel] errors building svn trunk
Using svn trunk, I get the following errors when trying to build. Any
suggestions?
[devgeo:/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork]$ ant
Buildfile: build.xml
cachingxslt:
all:
   [delete] Deleting:
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/cachingxslt/caching
xslt.jar
    [mkdir] Created dir:
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/cachingxslt/build
    [javac] Compiling 1 source file to
    [javac] Note:
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/cachingxslt/src/de/
fzi/dbs/xml/transform/CachingTransformerFactory.java uses unchecked or
unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
      [jar] Building jar:
xslt.jar
   [delete] Deleting directory
     [copy] Copying 1 file to
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/web/geonetwork/WEB-
INF/lib
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/web/intermap/WEB-IN
F/lib
jeeves:
all:
   [delete] Deleting:
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/jeeves/jeeves.jar
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/jeeves/build
    [javac] Compiling 87 source files to
    [javac] Note: Some input files use unchecked or unsafe operations.
      [jar] Building jar:
INF/lib
F/lib
schematron:
schematron:
compile-schematron:
     [echo] Parsing rules: none
     [echo] - generate xsl for reporting
     [xslt] java.lang.ClassNotFoundException:
org.apache.tools.ant.taskdefs.optional.TraXLiaison
     [xslt] at
org.apache.tools.ant.AntClassLoader.findClassInComponents(AntClassLoader
.java:1400)
     [xslt] at
org.apache.tools.ant.AntClassLoader.findClass(AntClassLoader.java:1341)
     [xslt] at
org.apache.tools.ant.AntClassLoader.loadClass(AntClassLoader.java:1088)
     [xslt] at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
     [xslt] at
java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
     [xslt] at java.lang.Class.forName0(Native Method)
     [xslt] at java.lang.Class.forName(Class.java:247)
     [xslt] at
org.apache.tools.ant.taskdefs.XSLTProcess.loadClass(XSLTProcess.java:552
     [xslt] at
org.apache.tools.ant.taskdefs.XSLTProcess.resolveProcessor(XSLTProcess.j
ava:533)
     [xslt] at
org.apache.tools.ant.taskdefs.XSLTProcess.getLiaison(XSLTProcess.java:78
5)
     [xslt] at
org.apache.tools.ant.taskdefs.XSLTProcess.execute(XSLTProcess.java:300)
     [xslt] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:288)
     [xslt] at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown
Source)
     [xslt] at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessor
Impl.java:25)
     [xslt] at java.lang.reflect.Method.invoke(Method.java:597)
     [xslt] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:1
06)
     [xslt] at org.apache.tools.ant.Task.perform(Task.java:348)
     [xslt] at org.apache.tools.ant.Target.execute(Target.java:357)
     [xslt] at
org.apache.tools.ant.Target.performTasks(Target.java:385)
     [xslt] at
org.apache.tools.ant.Project.executeSortedTargets(Project.java:1337)
     [xslt] at
org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleChe
ckExecutor.java:38)
     [xslt] at
org.apache.tools.ant.Project.executeTargets(Project.java:1189)
     [xslt] at
org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
     [xslt] at
Source)
     [xslt] at
Impl.java:25)
     [xslt] at
06)
     [xslt] at
     [xslt] at
     [xslt] at
ckExecutor.java:38)
     [xslt] at
     [xslt] at
     [xslt] at
Source)
     [xslt] at
Impl.java:25)
     [xslt] at
06)
     [xslt] at
     [xslt] at
     [xslt] at
org.apache.tools.ant.Project.executeTarget(Project.java:1306)
     [xslt] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecut
or.java:41)
     [xslt] at
     [xslt] at org.apache.tools.ant.Main.runBuild(Main.java:758)
     [xslt] at org.apache.tools.ant.Main.startAnt(Main.java:217)
     [xslt] at
org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
     [xslt] at
org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
BUILD FAILED
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/build.xml:34: The
following error occurred while executing this line:
/usr/local/wwwsites/tomcat/devgeo.cciw.ca/geonetwork/schematrons/build.x
ml:49: The following error occurred while executing this line:
ml:140: java.lang.ClassNotFoundException:
Total time: 5 seconds
hi,
did you install both the packages “ant” and “ant-optional” ?
Kind regards
Heikki Doeleman
On Wed, Apr 28, 2010 at 2:41 PM, Kralidis,Tom [Ontario] <Tom.Kralidis@anonymised.com> wrote:
suggestions?
devgeo:/usr/local/wwwsites/tomcat/[devgeo.cciw.ca/geonetwork]$ ant
cachingxslt:
all:
[delete] Deleting:
xslt.jar
[javac] Note:
unsafe operations.
[jar] Building jar:
xslt.jar
INF/lib
F/lib
jeeves:
all:
[delete] Deleting:
[jar] Building jar:
INF/lib
F/lib
schematron:
schematron:
compile-schematron:
[xslt] at
.java:1400)
[xslt] at
[xslt] at
[xslt] at
[xslt] at
[xslt] at
ava:533)
[xslt] at
5)
[xslt] at
[xslt] at
Source)
[xslt] at
Impl.java:25)
[xslt] at
06)
[xslt] at
[xslt] at
[xslt] at
ckExecutor.java:38)
[xslt] at
[xslt] at
[xslt] at
Source)
[xslt] at
Impl.java:25)
[xslt] at
06)
[xslt] at
[xslt] at
[xslt] at
ckExecutor.java:38)
[xslt] at
[xslt] at
[xslt] at
Source)
[xslt] at
Impl.java:25)
[xslt] at
06)
[xslt] at
[xslt] at
[xslt] at
[xslt] at
or.java:41)
[xslt] at
[xslt] at
[xslt] at
BUILD FAILED
GeoNetwork-devel mailing list
I installed ant-trax, which seemed to do the trick.
Thanks
..Tom
-----Original Message-----
Sent: Wednesday, 28 April 2010 09:05
To: Kralidis,Tom [Ontario]
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] errors building svn trunk
hi,
did you install both the packages "ant" and "ant-optional" ?
Kind regards
Heikki Doeleman
to build. Any
  suggestions?
  cachingxslt:
  all:
    [delete] Deleting:
lt/caching
  xslt.jar
     [javac] Note:
lt/src/de/
<http://devgeo.cciw.ca/geonetwork/cachingxslt/src/de/ fzi/db
s/xml/transform/CachingTransformerFactory.java> uses unchecked or
  unsafe operations.
       [jar] Building jar:
lt/caching
  xslt.jar
twork/WEB-
  INF/lib
<http://devgeo.cciw.ca/geonetwork/web/geonetwork/WEB- INF/lib&gt;
map/WEB-IN
  F/lib
<http://devgeo.cciw.ca/geonetwork/web/intermap/WEB-IN F/lib&gt;
  jeeves:
  all:
    [delete] Deleting:
unsafe operations.
       [jar] Building jar:
twork/WEB-
  INF/lib
map/WEB-IN
  F/lib
  schematron:
  schematron:
  compile-schematron:
      [xslt] at
lassLoader
  .java:1400)
      [xslt] at
ava:1341)
      [xslt] at
ava:1088)
      [xslt] at
      [xslt] at
      [xslt] at
s.java:552
      [xslt] at
TProcess.j
  ava:533)
      [xslt] at
ss.java:78
  5)
      [xslt] at
java:300)
      [xslt] at
      [xslt] at
  Source)
      [xslt] at
odAccessor
  Impl.java:25)
      [xslt] at
      [xslt] at
ils.java:1
  06)
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
(SingleChe
  ckExecutor.java:38)
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
  Source)
      [xslt] at
odAccessor
  Impl.java:25)
      [xslt] at
      [xslt] at
ils.java:1
  06)
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
(SingleChe
  ckExecutor.java:38)
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
  Source)
      [xslt] at
odAccessor
  Impl.java:25)
      [xslt] at
      [xslt] at
ils.java:1
  06)
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
aultExecut
  or.java:41)
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
      [xslt] at
  BUILD FAILED
ns/build.x
  ml:49
<http://devgeo.cciw.ca/geonetwork/schematrons/build.x ml:49&gt;
ns/build.x
  ml:140
<http://devgeo.cciw.ca/geonetwork/schematrons/build.x ml:140
