I'm finding quite a few places in XSLT scripts that
generate URLs containing un-escaped ampersands.
For example, graphover-show.xsl contains the fragment:
...get?access=public&id={/root/response/id}&fname=...
This ends up in the browser as:
...get?access=public&id=...&fname=...
but it _should_ be:
One way to proceed would be to change the XSLT script to say:
but is this the best way?
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
Hi Richard,
Does the below example generate an error for you?
Ciao,
Jeroen
but it _should_ be:
Richard Walker
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-devel mailing list
Jeroen Ticheler wrote:
Hi Richard,
I note that my previous e-mail looks very
strange in Nabble because every occurrence
of the sequence of characters
"ampersand a m p semicolon" appears
in the browser only as an ampersand. I really
did write just an ampersand in some places and
"ampersand a m p semicolon" in others! So for
the rest of this e-mail please mentally
replace each occurrence of "ampersand" with a
real ampersand.
I attach an example page generated via the graphover-show.xsl
script. I don't know how this example will get munged
by the mailing list or Nabble - the important line
reads "access=publicampersandid=10ampersandfname"
except with real ampersands.
If you put this into the W3C validator
(http://validator.w3.org/) you get
a number of errors related to the 'general entity "id"'
and 'general entity "fname"'.
The validator (correctly) parses
"access=publicampersandid=10"
as though it was "access=publicampersandid;=10",
i.e., by assuming a missing semicolon,
and then (correctly) rejects this as invalid HTML
because there is indeed no 'general entity "id"'.
Richard Walker
(attachments)
broken.html (237 Bytes)
I am pleased (and greatly relieved) to report
that:
1. It is a very, very longstanding error in the
HTML output method of Xalan-J:
http://issues.apache.org/jira/browse/XALANJ-611
2. The error has been fixed in Xalan-J version 2.7.1.
3. After replacing serializer.jar
and xalan.jar with the 2.7.1 versions, the
problem is fixed!
4. Saxon 9 also does the right thing.
But:
5. Someone should check the effect of upgrading
to 2.7.1 on the escapeXMLEntities template
defined in utils.xsl and used in metadata.xsl -
some of this escaping
may need to be modified, or indeed may no
longer be necessary. I can do this checking
if someone can give me a search query (either
on the example data or as a remote search)
that would trigger that bit of the code.
Richard Walker
OK, I had a look for myself. The "Hydrological basins"
sample metadata has an ampersand in the metadata. Switching
Xalan from 2.7.0 to 2.7.1 does _not_ alter the
display and editing of this metadata. (Phew.)
On looking at the code I can see why - the error in
Xalan that is fixed in version 2.7.1 is to do with ampersands
in attribute values, and the escapeXMLEntities template deals
with text nodes, and that worked correctly anyway.
But this did show up what might be considered
inconsistencies (or indeed, errors) in the presentation/editing
of metadata.
Try the following three things with the Hydrological
basins metadata while logged in as the "admin" user:
1. Bring up the "Default" view of the metadata,
and press the "Edit" button.
In the "OnLine resource" labelled
"Hydrological basins in Africa (Shapefile Format)",
observe the URL contains:
id=10 ampersand fname=basins.zip ampersand access=private
(If you use the browser's "View Source", you can see that
the ampersands are escaped in the value attribute of the
corresponding input element in the form's HTML because
of the escapeXMLEntities template,
but the browser renders them as raw ampersands.)
2. Press "Cancel", then press "XML view".
Copy and paste the metadata from the browser into
a file, and run your favourite XML parser on the file.
Ouch - it is not well-formed XML because there are
two unescaped ampersands!
Each ampersand should have been displayed in the browser as
ampersand amp semicolon.
3. Go back to the browser and press the
"Edit button". (You're now editing the metadata as "raw"
XML.) Search for "fname". Aha, the ampersands have
been correctly escaped in this view (because of the
escapeXMLEntities template).
Conclusions:
1. The "XML view" of the metadata can produce XML that
is not well-formed. That is surely an error, yes?
2. Editing in the Default view is different from editing
in the XML view - in the default view, ampersands are
not escaped; in the XML view, they are. An
inconsistency, but perhaps a reasonable one. But
this could be a "gotcha" for users.
Richard Walker
