[GeoNetwork-devel] Facets of lucene fields starting with _ in widget UI
Hi
Not sure if doing something wrong, but looks like the facets panel can’t manage lucene field names starting with _ .
Seem the name is taken from the summary of q service and no using config-summary.xml indexKey value. I see the FacetPanel uses facetListConfig, but not very clear if can be used to override the lucene field name?
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
