[GeoNetwork-devel] Feedback form and GeoNetwork Email
Hi everyone,
I'm trying to set up an auto generated email that will respond to users.
I think that I can create the email contents fine, but getting it to actually send is a problem. When I try to retrieve the host and port that was set in the config screens, I get a null in return for both params.
This is along the same error as this post:
http://www.nabble.com/feedback-form-td15413463s18419.html#a15413463
It's just in the wrong forum, and may not have reached the right people.
Is anyone else having the same problems? Any fixes/suggestions?
Thanks in advance
Hi Steve,
Just a shot in the dark... Did you configure the server and port in the System preferences panel under the web administration section?
Ciao,
Jeroen
On Feb 18, 2008, at 3:59 PM, Steve Sare wrote:
Hi everyone,
Thanks in advance
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-devel mailing list
Thanks for the suggestion. I did have the settings in the preferences.
I've figured it out.
Inside the Set.java file, the paths to host and port are set to:
system/feedback/mailServer/host
system/feedback/mailServer/port
And inside the Insert.java file (which is used for feedback)
The paths to retrieve the settings are set to:
system/feedback/smtpHost
system/feedback/smtpPort
You just have to change the paths on Insert.java to match the ones from Set.java
Sorry to bother you guys with this one.
Steve
Jeroen Ticheler wrote:
Hi Steve,
Ciao,
Jeroen
Hi everyone,
Thanks in advance
Thanks Steve!
Fixed and committed that, so it should work in RC2
Ciao,
Jeroen
