[GeoNetwork-devel] FGDC Element <metextns> not inserting correctly into geonetwork
Hello developers,
We have noticed that FGDC metadata with <metextns> does not insert correctly into Geonetwork. If you add <metextns> to the Geonetwork FGDC sample metadata record included with Geonetwork, a ClassCastException :java.util.ArrayList error is returned (error-log stack trace attached below) when the insert completes and forwards to the Edit page:
<metextns> <onlink>http://www.ngdc.noaa.gov/metadata/extensions/local_extensions.html&lt;/onlink&gt;
     <metprof>NGDC Extensions to FGDC Metadata</metprof>
</metextns>
Geonetwork is having trouble processing the <onlink> element
when contained within <metextns>. The onlink element processes
correctly outside of <metextns>. Note that the insert does
actually succeed; it's the Edit page that triggers the exception.
The <metextns> element is a mandatory element in our FGDC
metadata and therefore we need to find a solution to this problem. Any help or direction the Geonetwork community can provide is greatly
appreciated.
Thank you,
John
From geonetwork.log:
2008-09-16 13:54:45,827 ERROR [jeeves.service] - (C) Exc :
java.lang.ClassCastException: java.util.ArrayList cannot be cast to
java.lang.String
2008-09-16 13:54:45,827 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>java.util.ArrayList cannot be cast to
java.lang.String</message>
<class>ClassCastException</class>
<stack>
   <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java"
line="991" method="addValues" />
line="660" method="expandElement" />
line="617" method="expandTree" />
line="626" method="expandTree" />
line="134" method="addEditingInfo" />
   <at class="org.fao.geonet.kernel.DataManager"
file="DataManager.java" line="853" method="getMetadata" />
   <at class="org.fao.geonet.services.metadata.GetEditableData"
file="GetEditableData.java" line="72" method="exec" />
   <at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="238" method="execService" />
</stack>
John Kozimor
CIRES, National Geophysical Data Center/NOAA
P (303) 497-6729
F (303) 497-6513
http://ngdc.noaa.gov
Hi John,
I've fixed this - commit #1530 on trunk, #1531 on branches/2.2.x.
Simon
John Kozimor wrote:
Hello developers,
</metextns>
appreciated.
Thank you,
John
java.lang.String
executing service
<error id="error">
<stack>
</stack>
Hi Simon,
I get the same error with FGDC data as Jhon described. You said that you
fixed this, could you explain a little bit more how this can be solved. I
don't see a way how to solve this from your answer.
I'm using GN 2.2.0.
Thank you!
Torsten
Simon Pigot-6 wrote:
Hi John,
Simon
John Kozimor wrote:
Hello developers,
<metextns>
</metextns>
appreciated.
Thank you,
John
java.lang.String
executing service
<error id="error">
<stack>
</stack>
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-devel mailing list
View this message in context: http://www.nabble.com/FGDC-Element-<metextns>-not-inserting-correctly-into-geonetwork-tp19692822p20766215.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hi Simon,
I'm using GN 2.2.0.
Thank you!
Torsten
Hi John,
Simon
John Kozimor wrote:
Hello developers,
<metextns>
</metextns>
appreciated.
Thank you,
John
java.lang.String
executing service
<error id="error">
<stack>
</stack>
challenge
prizes
world
Hi John,
Simon
John Kozimor wrote:
Hello developers,
<metextns>
</metextns>
appreciated.
Thank you,
John
java.lang.String
executing service
<error id="error">
<stack>
</stack>
challenge
prizes
world
View this message in context: http://www.nabble.com/FGDC-Element-<metextns>-not-inserting-correctly-into-geonetwork-tp19692822p20766250.html
Hi Torsten,
Probably by getting sources from trunk (HEAD revision or upper than #1530), or from branches/2.2.x.
You could build them and get your own installer using ant scripts.
HTH,
Mathieu
On Mon, Dec 1, 2008 at 6:14 AM, Torsten3y <torstendrey@anonymised.com> wrote:
Hi Simon,
don’t see a way how to solve this from your answer.
I’m using GN 2.2.0.
Thank you!
Torsten
Hi John,
I’ve fixed this - commit #1530 on trunk, #1531 on branches/2.2.x.
Simon
John Kozimor wrote:
Hello developers,
We have noticed that FGDC metadata with does not insert
correctly into Geonetwork. If you add to the Geonetwork FGDC
[http://www.ngdc.noaa.gov/metadata/extensions/local_extensions.html](http://www.ngdc.noaa.gov/metadata/extensions/local_extensions.html) NGDC Extensions to FGDC Metadata
Geonetwork is having trouble processing the element
when contained within . The onlink element processes
correctly outside of . Note that the insert does
actually succeed; it’s the Edit page that triggers the exception.
The element is a mandatory element in our FGDC
appreciated.
Thank you,
John
java.lang.String
executing service
java.lang.String
ClassCastException
This SF.Net email is sponsored by the Moblin Your Move Developer’s
challenge
prizes
world
Hi John,
Simon
John Kozimor wrote:
Hello developers,
appreciated.
Thank you,
John
java.lang.String
executing service
java.lang.String
ClassCastException
challenge
prizes
world
View this message in context: http://www.nabble.com/FGDC-Element-%3Cmetextns%3E-not-inserting-correctly-into-geonetwork-tp19692822p20766250.html
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
Mathieu Coudert
mcoudert@anonymised.com
Hi Mathieu,
thanks for your fast reply!
It helps a bit, regarding this document (http://www.fao.org/geonetwork/docs/ch15s03.html) I have to install the source code and than compile GN. How do I make sure that I get the trunk #1530 or upper, i.e. what do I have to tell ant?
I'm relative new to GN and never compiled it, so far I just used the desktop version to test it.
Torsten
Mathieu Coudert wrote:
Hi Torsten,
HTH,
Mathieu
On Mon, Dec 1, 2008 at 6:14 AM, Torsten3y <torstendrey@anonymised.com <mailto:torstendrey@anonymised.com>> wrote:
    Hi Simon,
    that you
    solved. I
    I'm using GN 2.2.0. <http://2.2.0.>
    Thank you!
    Torsten
    > Hi John,
    > I've fixed this - commit #1530 on trunk, #1531 on branches/2.2.x.
    > Cheers,
    > Simon
    > John Kozimor wrote:
    >> Hello developers,
    >> We have noticed that FGDC metadata with <metextns> does not insert
    >> correctly into Geonetwork. If you add <metextns> to the
    Geonetwork FGDC
    >> sample metadata record included with Geonetwork, a
    ClassCastException
    >> :java.util.ArrayList error is returned (error-log stack trace
    attached
    >> below) when the insert completes and forwards to the Edit page:
    >> <metextns>
    >> <metprof>NGDC Extensions to FGDC Metadata</metprof>
    >> </metextns>
    >> Geonetwork is having trouble processing the <onlink> element
    >> when contained within <metextns>. The onlink element processes
    >> correctly outside of <metextns>. Note that the insert does
    >> actually succeed; it's the Edit page that triggers the exception.
    >> The <metextns> element is a mandatory element in our FGDC
    >> metadata and therefore we need to find a solution to this problem.
    >> Any help or direction the Geonetwork community can provide is
    greatly
    >> appreciated.
    >> Thank you,
    >> John
    >> >From geonetwork.log:
    >> 2008-09-16 13:54:45,827 ERROR [jeeves.service] - (C) Exc :
    >> java.lang.ClassCastException: java.util.ArrayList cannot be cast to
    >> java.lang.String
    >> 2008-09-16 13:54:45,827 DEBUG [jeeves.service] - Raised
    exception while
    >> executing service
    >> <error id="error">
    >> <message>java.util.ArrayList cannot be cast to
    >> java.lang.String</message>
    >> <class>ClassCastException</class>
    >> <stack>
    >> <at class="org.fao.geonet.kernel.EditLib" file="EditLib.java"
    >> line="991" method="addValues" />
    >> line="660" method="expandElement" />
    >> line="617" method="expandTree" />
    >> line="626" method="expandTree" />
    >> line="134" method="addEditingInfo" />
    >> <at class="org.fao.geonet.kernel.DataManager"
    >> file="DataManager.java" line="853" method="getMetadata" />
    >> <at class="org.fao.geonet.services.metadata.GetEditableData"
    >> file="GetEditableData.java" line="72" method="exec" />
    >> <at class="jeeves.server.dispatchers.ServiceInfo"
    >> file="ServiceInfo.java" line="238" method="execService" />
    >> </stack>
    > This SF.Net email is sponsored by the Moblin Your Move Developer's
    > challenge
    > Build the coolest Linux based applications with Moblin SDK & win
    great
    > prizes
    > Grand prize is a trip for two to an Open Source event anywhere
    in the
    > world
    > http://moblin-contest.org/redirect.php?banner_id=100&url=/
    <http://moblin-contest.org/redirect.php?banner_id=100&url=/&gt;
    > GeoNetwork-devel mailing list
    > GeoNetwork-devel@lists.sourceforge.net
    <mailto:GeoNetwork-devel@lists.sourceforge.net>
    > https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
    > GeoNetwork OpenSource is maintained at
    > http://sourceforge.net/projects/geonetwork
    > Hi John,
    > Cheers,
    > Simon
    Geonetwork FGDC
    ClassCastException
    attached
    >> <metextns>
    >> </metextns>
    greatly
    >> appreciated.
    >> Thank you,
    >> John
    >> java.lang.String
    exception while
    >> <stack>
    >> </stack>
    > challenge
    great
    > prizes
    in the
    > world
    challenge
    great prizes
    the world
Mathieu Coudert
mcoudert@anonymised.com <mailto:mcoudert@anonymised.com>
On Mon, Dec 1, 2008 at 8:17 AM, Torsten <torstendrey@anonymised.com> wrote:
Hi Mathieu,
Making a svn checkout command on the trunk will retrieve you the HEAD revision, which is the last revision on trunk.
So don’t worry, if you do not specify any option to your checkout on trunk, you will get an upper revision than #1530.
Concerning ant, once it is install on your computer, you just have to run the ant command in the appropriate repository, as it is mentionned here :
The ant command will run the default target in ant script : which leads to compile geonetwork sources for the first script, and to build the installer for the second one.
Mathieu
