[GeoNetwork-devel] fgdc metadata standard
How do you display a preview thumbnail in the results section of a metadata
search using the fgdc standard. I saw an article about hyperlinking and
making some changes to two xsl files (which i did) but what do you have to
to to see the actual thumbnail. Which field in the metadata xml form allows
for the display of a thumbnail preview
thank you
Damian
View this message in context: http://www.nabble.com/fgdc-metadata-standard-tf3831384s18419.html#a10846935
Sent from the geonetwork-devel mailing list archive at Nabble.com.
