- Hi Damian
We also needed to display the thumbnails for the FGDC metadata,
in the directory \geonetwork\web\xsl add in lower case the lines in red
in the file metadata-fgdc-std.xsl
<xsl:copy-of select=“idinfo/citation/citeinfo/title”/>
<xsl:copy-of select=“idinfo/descript/abstract”/>
<xsl:copy-of select=“idinfo/browse/browsen”/>
in the file metadata-utils.xsl
<xsl:when test=“$metadata/browsen”>
Click on image for larger view
</xsl:when>
xsl:otherwise
</xsl:otherwise>
1.10.1 Browse Graphic File Name -- name of a related graphic file that provides an illustration of the data set.
Type: text
Domain: free text
Short Name: browsen
See you
Ivan Israel
Date: Mon, 28 May 2007 19:14:54 -0700
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] fgdc metadata standardHow do you display a preview thumbnail in the results section of a metadata
search using the fgdc standard. I saw an article about hyperlinking and
making some changes to two xsl files (which i did) but what do you have to
to to see the actual thumbnail. Which field in the metadata xml form allows
for the display of a thumbnail previewthank you
DamianView this message in context: http://www.nabble.com/fgdc-metadata-standard-tf3831384s18419.html#a10846935
Sent from the geonetwork-devel mailing list archive at Nabble.com.
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-devel mailing list
Explore the seven wonders of the world Learn more!
