[GeoNetwork-devel] FGDC to ISO transformations
Dear Jacqueline,
For some reason I did only now see this email. Could you tell me what the license is the XSLT files are released under? I'm the chair of the GeoNetwork opensource geospatial catalogue software and I'm aware that there are a substantial number of users interested in having the FGDC CSDGM to ISO translation readily available in the software. Any new source code we add to the project should have a license that is compliant with the GPL software license GeoNetwork is released under to ensure the code can freely be distributed without running into copyright or license issues.
Second question: I see this is version 1.0, so I can assume it is pretty much final? Do you see a new (bug fix) release coming up soon?
Thanks in advance, regards,
Jeroen
On Sep 17, 2009, at 3:39 PM, Jacqueline Mize wrote:
The Metadata Transform Working Group (made of members from the FGDC Metadata Working Group, NOAA’s National Ocean Survey, National Geophysical Data Center, and National Ocean Data Center; the U.S. Geological Survey; and various other organizations) has been collaboratively building transforms for the transition of metadata among standards. As the development of these transforms and libraries for translation of content is a collaborative effort, any questions or comments can be sent to ncddcmetadata@anonymised.com to be passed along to the working group.
  * *FGDC CSDGM to ISO Transforms
    <http://www.ncddc.noaa.gov/metadataresource/metadataandxml/files/CSDGMtoISOv1.zip&gt;\*
    - A zip file containing the FGDC CSDGM to ISO Version 1.0
    transform using the MD_Metadata root. Once unzipped, there will be
    four .xslt files, FGDC CSDGM to ISO 19115, FGDC CSDGM to ISO 19110
    (FC), FGDC CSDGM to ISO 19111 (MD_CRS), and FGDC CSDGM to ISO
    19111 (baseCRS).
  * *FGDC CSDGM to ISO Test Cases
    <http://www.ncddc.noaa.gov/metadataresource/metadataandxml/files/CSDGMtoISOv1test.zip&gt;\*
    - This is a zip file that contains input and output files of
    multiple test cases for transforming FGDC CSDGM xml records to ISO
    19115, ISO 19110 (Feature Catalog), and ISO 19111 (CRS) xml
    records. These records coordinate with the CSDGM to ISO v1 xslt.
  * *FGDC CSDGM to ISO Crosswalk
    <http://www.ncddc.noaa.gov/metadataresource/metadataandxml/files/CSDGM2ISOxwalkv1.xls&gt;\*
    - A crosswalk from FGDC CSDGM to ISO 19115. This crosswalk
    incorporates feature catalogs (ISO 19110) and coordinate reference
    systems (ISO 19111) while also providing comments for suggested
    best practices.
  * *FGDC BIO to ISO Transforms
    <http://www.ncddc.noaa.gov/metadataresource/metadataandxml/files/FGDCBio2ISOv1.zip&gt;\*
    - A zip file containing the FGDC Biological Profile to ISO Version
    1.0 transform using the MD_Metadata root. Once unzipped, there
    will be four .xslt files, FGDC Bioto ISO 19115, FGDC Bio to ISO
    19110 (FC), FGDC Bioto ISO 19111 (MD_CRS), and FGDC Bio to ISO
    19111 (baseCRS).
  * *FGDC BIO to ISO Test Cases
    <http://www.ncddc.noaa.gov/metadataresource/metadataandxml/files/BIOtoISO.zip&gt;\*
    multiple test cases for transforming FGDC Biological Profile xml
    records to ISO 19115, ISO 19110 (Feature Catalog), and ISO 19111
    (CRS) xml records.
  * *FGDC BIO to ISO Crosswalk
    <http://www.ncddc.noaa.gov/metadataresource/metadataandxml/files/FGDCBIO2ISOxwalkv1.xls&gt;\*
    - A crosswalk from FGDC Biological Profile to ISO 19115. This
    crosswalk also incorporates feature catalogs (ISO 19110) and
    coordinate reference systems (ISO 19111). The goal of this
    crosswalk is to document the transform developed by the working
    group between the FGDC-STD-001.1-1999 and ISO 19115:2003. Please
    pay special attention to comments that are italicized.
Thanks for any comments and suggestions.
-Jaci
Jacqueline Mize
Geospatial Analyst, Radiance Technologies
NOAA\NCDDC
Stennis Space Center, MS
228.688.2174
Jacqueline.Mize@anonymised.com
metadata mailing list
http://lists.geocomm.com/mailman/listinfo/metadata
_____________________________________
This List is brought to you by:
The GeoCommunity and The GISDataDepot
http://www.geocomm.com/ | http://data.geocomm.com/
