[GeoNetwork-devel] File upload popup not displaying errors in IE
Hi
The file upload popup in metadata editor seem not working well in IE. For example, uploading same file to a metadata record without checking Overwrite option in FF shows a message like:
Error
File upload unsuccessful.
Exception : File upload unsuccessful because csw.xml already exists and overwrite was not permitted
but not the same in IE: no message is displayed, so no feedback to user.
Seem is used webtoolkit.aim.js to manage about the file upload and for IE fails in line 40 with Permission denied. Line 40:
if (i.contentDocument) {
Anyone has an idea of this?
Also a question: why use this library for file uploads? Can’t be handle with Prototype that is extensively used already? Maybe there’s a very good reason to use it, but we have lots of javascript libraries in GeoNetwork. In case that no good reason, I would like to change the code to avoid it.
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
