[GeoNetwork-devel] Filtering based on availability
Hi All,
We’re looking at how we might filter out or disable collections which are not accessible in our portal, which uses Geonetwork as the backend search engine.
Our use case is as follows:
  • Our metadata records relate one to one to feature types served by wms/wfs services
  • If the wms/wfs service is unavailable/slow or just unreliable we’d like to be able to flag it as such or not show it at all in our portal (in which case facet counts would need to reflect only what’s visible),
  • We intend to harvest records of this type from a number of providers including our own so records in our GeoNetwork instance will be harvested records
  • We want unavailable services to be detected and records filtered out or marked as unavailable automatically.
We’ve considered a number of options including a filtering process separate to Geonetwork, but have some issues with this approach with respect to accuracy of facet counts etc.
We’ve also looking at unpublishing records, but this conflicts with normal publishing workflow and is problematic for harvested records.
We are now looking at how we may include filtering based on accessibility as a plugin to GeoNetwork. I’m thinking of some type of custom filter functionality where the filter value is not sourced from the metadata record, but from another service and is regularly updated or to allow custom filters to be applied at search time.
What I’m wondering is a) whether anyone else has looked at this problem/if there are solutions already implemented or in progess, or, if not, b) whether the ability to plugin in this functionality may be a desirable enhancement for GeoNetwork when we’ve finished, in which case we can invest some time in ensuring that the functionality will be suitable for this purpose.
Craig Jones
Integrated Marine Observing System
Hi All,
I’ll take the lack of response as confirmation that there is no work going on in this space.
I’d be interested in getting comments on our proposed approach prior to starting on the work (so that we can take this into account if possible before we start rather than after)
Please refer to:
https://github.com/geonetwork/core-geonetwork/wiki/201411PluggableFilters
If you could make the time to review and comment on approach/suitability for inclusion in core that would be great.
Craig Jones
-------- Forwarded Message --------
Subject:
Date:
Fri, 14 Nov 2014 17:42:19 +1100
Craig Jones <Craig.Jones@anonymised.com>
To:
Devel geonetwork-devel@lists.sourceforge.net <geonetwork-devel@lists.sourceforge.net>
CC:
Peter Blain <Peter.Blain@anonymised.com>
Hi All,
Craig Jones
Hi Craig,
I love the proposal. The one thing comment I have is about the isFilterRequired(Element) method. We are migrating away from Jeeves to Spring MVC and the search parameters will probably be created from Map<String,String> instead of Element in the future. That said it is just something to be aware of. That change will probably take some time yet.
Jesse
On Thu, Nov 20, 2014 at 8:20 AM, Craig Jones <Craig.Jones@anonymised.com> wrote:
Hi All,
Please refer to:
Craig Jones
Subject:
Date:
To:
CC:
Hi All,
Craig Jones
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=157005751&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Thanks Jesse. No problems incorporating that when the time comes.
On 20/11/14 18:30, Jesse Eichar wrote:
Hi Craig,
Jesse
On Thu, Nov 20, 2014 at 8:20 AM, Craig Jones <Craig.Jones@anonymised.com <mailto:Craig.Jones@anonymised.com>> wrote:
    Hi All,
    I'll take the lack of response as confirmation that there is no
    I'd be interested in getting comments on our proposed approach
    Please refer to:
    Craig Jones
    Subject: Filtering based on availability
    Date: Fri, 14 Nov 2014 17:42:19 +1100
    To: Devel geonetwork-devel@lists.sourceforge.net
    <mailto:geonetwork-devel@lists.sourceforge.net>
    CC: Peter Blain <Peter.Blain@anonymised.com>
    <mailto:Peter.Blain@anonymised.com>
    Hi All,
    We're looking at how we might filter out or disable collections
      * Our metadata records relate one to one to feature types served
        by wms/wfs services
      * If the wms/wfs service is unavailable/slow or just unreliable
        we'd like to be able to flag it as such or not show it at all
        reflect only what's visible),
      * We intend to harvest records of this type from a number of
      * We want unavailable services to be detected and records
    We've considered a number of options including a filtering process
    We've also looking at unpublishing records, but this conflicts
    records.
    accessibility as a plugin to GeoNetwork. I'm thinking of some type
    search time.
    What I'm wondering is a) whether anyone else has looked at this
    may be a desirable enhancement for GeoNetwork when we've finished,
    Craig Jones
    Dashboards
    & more
    corporations, FREE
    <mailto:GeoNetwork-devel@lists.sourceforge.net>
Hi Craig,
There are definitely times (as in your use case) when this is desirable and so a filter plugin architecture would be good for supporting not just your use case but others as well. I'm not working on anything like this but I am working on other projects that rely on the catalog for information about services delivering data so any mechanism that can improve the reliability of those results would be very useful. I like the approach as stated in your proposal and I believe it will be suitable for inclusion into trunk when complete.
+1 from me.
Cheers and thanks,
Simon
________________________________________
Sent: Thursday, 20 November 2014 6:20 PM
Subject: [GeoNetwork-devel] Filtering based on availability
Hi All,
I'll take the lack of response as confirmation that there is no work going on in this space.
I'd be interested in getting comments on our proposed approach prior to starting on the work (so that we can take this into account if possible before we start rather than after)
Please refer to:
Craig Jones
From: Craig Jones <Craig.Jones@anonymised.com><mailto:Craig.Jones@anonymised.com>
To: Devel geonetwork-devel@lists.sourceforge.net<mailto:geonetwork-devel@lists.sourceforge.net> <geonetwork-devel@lists.sourceforge.net><mailto:geonetwork-devel@lists.sourceforge.net>
CC: Peter Blain <Peter.Blain@anonymised.com><mailto:Peter.Blain@anonymised.com>
Hi All,
We're looking at how we might filter out or disable collections which are not accessible in our portal, which uses Geonetwork as the backend search engine.
  * Our metadata records relate one to one to feature types served by wms/wfs services
  * If the wms/wfs service is unavailable/slow or just unreliable we'd like to be able to flag it as such or not show it at all in our portal (in which case facet counts would need to reflect only what's visible),
  * We intend to harvest records of this type from a number of providers including our own so records in our GeoNetwork instance will be harvested records
  * We want unavailable services to be detected and records filtered out or marked as unavailable automatically.
We've considered a number of options including a filtering process separate to Geonetwork, but have some issues with this approach with respect to accuracy of facet counts etc.
We've also looking at unpublishing records, but this conflicts with normal publishing workflow and is problematic for harvested records.
We are now looking at how we may include filtering based on accessibility as a plugin to GeoNetwork. I'm thinking of some type of custom filter functionality where the filter value is not sourced from the metadata record, but from another service and is regularly updated or to allow custom filters to be applied at search time.
What I'm wondering is a) whether anyone else has looked at this problem/if there are solutions already implemented or in progess, or, if not, b) whether the ability to plugin in this functionality may be a desirable enhancement for GeoNetwork when we've finished, in which case we can invest some time in ensuring that the functionality will be suitable for this purpose.
Craig Jones
