[GeoNetwork-devel] Fix for info buttons for layers
The problem:
Open the map viewer.
Below the map viewer, click "+".
Click on "NASA JPL . . .".
See the little blue "i" next to some services,
  e.g. "WMS Global Mosaic, not pan sharpened".
Click one of the little blue "i" buttons.
Nothing happens!
You should get a popup. You don't.
The problem is that setting innerHTML isn't
enough to cause execution of an embedded <script> tag,
which in this case contains the definition of
getWmsLayerInfo().
Here is a fix, which I have tested on Linux and Windows,
Firefox 2 and IE7.
My guess is that these buttons have not worked since the
definition of getWmsLayerInfo() was commented out
in main-page.xsl in SVN revision 955, i.e. in November.
Sorry, this is really a fix for Intermap - what
is the correct protocol here?
The fix deliberately evaluates _only_ the first
<script> tag it finds in the AJAX reply so there's
no chance of a picking up a <script>
tag from a malicious remote server's data.
I don't know if that's even possible, but
better safe than sorry . . . .
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
(attachments)
popup-fix.txt (2.07 KB)
Hi Richard,
Thanks! I applied the fix to the source code and committed it to SVN
Ciao,
Jeroen
On Feb 21, 2008, at 8:25 AM, Software Improvements gn-devel wrote:
The problem:
Nothing happens!
getWmsLayerInfo().
Firefox 2 and IE7.
-- Richard Walker
Index: web/intermap/scripts/im_extras.js
--- web/intermap/scripts/im_extras.js (revision 1125)
+++ web/intermap/scripts/im_extras.js (working copy)
@@ -8,6 +8,7 @@
requires:
    clearNode(node)
+ extractScripts() // from prototype.js
    getIMServiceURL(service)
    imc_addServices(url, services, type, im_servicesAdded);
  im_buildLayerList(req); // rebuild layers' list
@@ -143,9 +144,13 @@
function im_servicesLoaded(req)
- // Dinamically generate content
+ // Dynamically generate content
  var im = $('im_serverList');
  im.innerHTML =req.responseText;
+ var reqScripts = req.responseText.extractScripts();
+ // Only evaluate the first script
+ if (reqScripts.length > 0)
+ eval(reqScripts[0]);
Index: web/intermap/xsl/im_get-services-embedded.xsl
--- web/intermap/xsl/im_get-services-embedded.xsl (revision 1125)
+++ web/intermap/xsl/im_get-services-embedded.xsl (working copy)
@@ -1,5 +1,8 @@
+<!-- requires unescapeHTML() from prototype.js -->
+<!-- only the first script tag will be evaluated by im_servicesLoaded() -->
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot;&gt;
  <!-- Main template -->
@@ -10,7 +13,7 @@
      <script language="javascript">
        //function getWmsLayerInfo(name) {
        getWmsLayerInfo = function(name) {
- window.open('<xsl:value-of select="/root/gui/locService" />/map.service.wmsLayerInfo?url=<xsl:value-of select="/root/response/url"/>&amp;name=' + name, 'dialog', 'HEIGHT=300,WIDTH=400,scrollbars=yes,toolbar=no,status=no,menubar=no,location=no,resizable=yes');
+ window.open(('<xsl:value-of select="/root/gui/locService" />/map.service.wmsLayerInfo?url=<xsl:value-of select="/root/response/url"/>&amp;name=' + name).unescapeHTML(), 'dialog', 'HEIGHT=300,WIDTH=400,scrollbars=yes,toolbar=no,status=no,menubar=no,location=no,resizable=yes').focus();
      </script>
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-devel mailing list
