[GeoNetwork-devel] Forward to localhost:8080?
I am testing 2.6.1 for release and hitting a very strange effect that doesn’t happen with 2.6.0.
I am using the Jetty container fronted by Apache on port 80 with a ProxyPass for /geonetwork to localhost:8080/geonetwork.
If I start the 2.6.0 server everything is fine.
Stop the 2.6.0 server and start the 2.6.1 server (pointing at the same database – config.xml is identical apart from the uploadDir and the additional SQL Server block).
The front page is returned correctly, but the log in button forwards to “http://localhost:8080/geonetwork/…”.
Stop the 2.6.1 server and restart the 2.6.0 (then restart Apache) and everything is fine again.
I cannot imagine what the problem might be. Any suggestions?
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
