Hello,
Install the version 1.2 of GeoNode on Ubuntu Server 12.04 64bit server, and then of course Geonework install the 2.6.2 version.
My question is this:
I’m trying to print PDF of complete metadata in GeoNetwork but only prints:
- the summary
- keywords
- Scheme
- unique identifier
And according to my configuration, a download link metadata which directs me to a page where metadata are displayed …
Would it be possible that instead of a download link metadata to show me the same PDF file download? …
It is the option that is on the menu: → Print to PDF.
Thank you.
Sergio.
So it appears to me you have made a search. Selected a metadata then performed a print on that selection. That is not intended to print the full metadata. Just print a summary of the selected items.
DO I understand the problem correctly?
Jesse
On Mon, May 13, 2013 at 7:38 PM, Sergio Cabrera <ccheco25@anonymised.com> wrote:
Hello,
- the summary
- keywords
- Scheme
- unique identifier
Thank you.
Sergio.
AlienVault Unified Security Management (USM) platform delivers complete
security visibility with the essential security capabilities. Easily and
efficiently configure, manage, and operate all of your security controls
from a single console and one unified framework. Download a free trial.
http://p.sf.net/sfu/alienvault_d2d
GeoNetwork-devel mailing list
You’re right.
Then, the complete print PDF of metadata is not possible with the version that I have installed. That functionality will come with a newer version or not?
Thank you.
Sergio
Hello,
- the summary
- keywords
- Scheme
- unique identifier
Thank you.
Sergio.
In the new version there is a PDF print option. FOr example:
http://ids.pigma.org/geonetwork/srv/fre/pdf?uuid=23fd6088-0e69-4e16-89a0-ad0854119e5e
I think that is more or less the default PDF print now. (With some custom branding I am sure).
Also with a bit of development you can have an output like geocat.ch has:
http://www.geocat.ch/geonetwork/srv/eng/pdf?uuid=b7630e06-7e06-4ab0-9ed5-9fd2e66b6433
The difference between the two is that the first is an xslt transform that creates a PDF. This means that it is not identical to the output of the metadata.show service. The second option (the one used by geocat). Takes the HTML and converts it a PDF it is literally identical to the output of the metadata.show output.
The first is available in 2.8 and 2.10. The second would have to be ported to the system.
Jesse
On Mon, May 13, 2013 at 9:41 PM, Sergio Cabrera <ccheco25@anonymised.com> wrote:
You’re right.
Thank you.
Sergio
---------- Forwarded message ----------
From: Jesse Eichar <jesse.eichar@anonymised.com…189…>
Date: 2013/5/13
Subject: Re: [GeoNetwork-devel] Full printing PDF Metadata
To: Sergio Cabrera <ccheco25@anonymised.com>
Cc: “Devel geonetwork-devel@anonymised.comts.sourceforge.net” <geonetwork-devel@lists.sourceforge.net>
Jesse
On Mon, May 13, 2013 at 7:38 PM, Sergio Cabrera <ccheco25@anonymised.com.31…> wrote:
Hello,
- the summary
- keywords
- Scheme
- unique identifier
Thank you.
Sergio.
