Hi Claudia,
you should send us at least the logs, the oracle version and the url where geonetwork
is running with the problem manifested.
Hi Mr.Ticheler and Miss Carboni
I tried to post a message in Geonetwork-devel list but I don't know if you and all group received it. Can you help with this, please.
Claudia-----Original Message-----
From: geonetwork-devel-bounces@lists.sourceforge.net [mailto:geonetwork-devel-bounces@lists.sourceforge.net]On Behalf Of Perea, Claudia Jimena (CIAT)
Sent: Wednesday, January 17, 2007 9:32 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Oracle Connection Problems - GN 2.0.2
Importance: HighHi all,
I am working with the CIAT Geonetwork node and I have had some problems when I try to access to web application using a JDBC connection to Oracle Database.
The web application works fine, but the metadata from Oracle database are not shown. I have installed GN using Apache Tomcat 5, Java 1.5.
It happens frequently so we have to restart tomcat service and check the database to solve this problem, and it is not very recommended to restart any time the application server because we have another applications working all the time.
So, can you help why it is happening this ?
Claudia
