[GeoNetwork-devel] FW: Oracle Connection Problems - GN 2.0.2
Hi Andrea
Thanks for your reply.
The URL is http://gisweb.ciat.cgiar.org:8080/geonetwork/ but it is working now, I talked with the DBA and he told me the user and password to connect to the Oracle 8i was expired, so he fixed it.
So I think the problems was that....if i have problems again I will contact you again.
Best Regards,
Claudia
-----Original Message-----
From: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net]On Behalf Of
Andrea Carboni
Sent: Monday, January 22, 2007 3:17 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] FW: Oracle Connection Problems - GN
2.0.2
Hi Claudia,
you should send us at least the logs, the oracle version and the url where geonetwork
is running with the problem manifested.
Hi Mr.Ticheler and Miss Carboni
I tried to post a message in Geonetwork-devel list but I don't know if you and all group received it. Can you help with this, please.
Claudia
From: geonetwork-devel-bounces@lists.sourceforge.net [mailto:geonetwork-devel-bounces@lists.sourceforge.net]On Behalf Of Perea, Claudia Jimena (CIAT)
Sent: Wednesday, January 17, 2007 9:32 AM
Subject: [GeoNetwork-devel] Oracle Connection Problems - GN 2.0.2
Importance: High
I am working with the CIAT Geonetwork node and I have had some problems when I try to access to web application using a JDBC connection to Oracle Database.
The web application works fine, but the metadata from Oracle database are not shown. I have installed GN using Apache Tomcat 5, Java 1.5.
It happens frequently so we have to restart tomcat service and check the database to solve this problem, and it is not very recommended to restart any time the application server because we have another applications working all the time.
So, can you help why it is happening this ?
Claudia
opinions on IT & business topics through brief surveys - and earn cash
GeoNetwork-devel mailing list
