Hi
Since this commit: c694a7415db6bc5bae072577c2e6653ac140cb77 (https://github.com/geonetwork/core-geonetwork/commit/c694a7415db6bc5bae072577c2e6653ac140cb77#web) GAST is not available, causing issues in the installer build and failing the nightly build.
The commit seem not related to GAST. Does anyone knows if has been removed accidentaly? or should just update the installer script to don’t use it from now?
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose,
I have made the updates locally to remove GAST from the installed - I have
supplied a pull request to remove it. But like you I would like to get
confirmation that this was not removed by accident.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gast-submodule-tp5069284p5071762.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Ian
Thanks. I tried similar changes, but would like to know why GAST was removed before any additional commit, as the commit c694a7415db6bc5bae072577c2e6653ac140cb77 where was removed seem not related to GAST.
Seem nobody knows about this?
Jose García
On Fri, Aug 9, 2013 at 6:11 PM, ianwallen <ianwallen@anonymised.com> wrote:
Jose,
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It’s a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose, Ian,
small question: where do you see in commit c694a7415db6bc5bae072577c2e6653ac140cb77 that GAST was removed ? I just see “Showing 2 changed files with 15 additions and 6 deletions.” but that’s not GAST. Where do you see it was here that GAST got removed ?
Kind regards
Heikki Doeleman
Jose,
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
For the develop branch we discussed at the code sprint about removing gast and making it a standalone project. There were problems related to the refactoring and GAST so I dropped it and have been meaning to finish the work on the gast standalone project.
I didn’t realize the installer required it and I will look into that ASAP.
Jesse
On Fri, Aug 9, 2013 at 7:37 PM, heikki <tropicano@anonymised.com> wrote:
Jose, Ian,
Kind regards
Heikki Doeleman
On Fri, Aug 9, 2013 at 7:18 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Ian
Jose García
Jose,
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2013/8/12 Jesse Eichar <jesse.eichar@anonymised.com>:
BTW, for me, it's fine to just drop GAST. Does anyone using it ? and
for what action ?
Cheers.
Francois
I didn't realize the installer required it and I will look into that ASAP.
Jesse
Jose, Ian,
"Showing 2 changed files with 15 additions and 6 deletions." but that's not
Kind regards
Heikki Doeleman
wrote:
Hi Ian
to GAST.
Jose García
Jose,
have
It's a free troubleshooting tool designed for production.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Heikki
I was comparing the revisions and unless I’m wrong, in previous revision gast was there, but not in c694a7415db6bc5bae072577c2e6653ac140cb77.
Jose García
Jose, Ian,
Kind regards
Heikki Doeleman
Hi Ian
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose,
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
