Fellow Geonetworkers,
I'm mystified!
If we have an FGDC record with an element, any element, longer than about 3000 characters, it won't validate. (And we have many metadata records we receive from other institutions like this.) We get the "Validation Error...Metadata is not valid." error page. The geonetwork.log file shows:
StackOverflowError in com.sun.org.apache.xerces.internal.impl.xpath.regex.RegularExpression.matchString()
As soon as I delete enough characters to get below 3000 in length, the record validates.
Has anyone seen this error?
We have discovered that adding "-Xss2M" to start-geonetwork.sh to increase the Java stack size seems to solve the problem. Is this a reasonable solution, and should it be added to the 2.4 standard installation?
Thanks for any input,
--Rich
Richard Fozzard, Computer Scientist
Geospatial Metadata at NGDC: http://www.ngdc.noaa.gov/metadata
Cooperative Institute for Research in Environmental Sciences (CIRES)
Univ. Colorado & NOAA National Geophysical Data Center, Enterprise Data Systems 325 S. Broadway, Skaggs 1B-305, Boulder, CO 80305
Office: 303-497-6487, Cell: 303-579-5615, Email: richard.fozzard@anonymised.com
Details:
We're running GN 2.2 using Tomcat/5.5.23, Java 1.6.0_13-b03, and Oracle 10.2 on Red Hat Linux EL3. I've confirmed that this bug also appears on a plain GN2.2, Jetty, McKoi installation on Red Hat EL5, on GN 2.2 and 2.4RC0 on Windows.
geonetwork.log:
2009-04-09 14:44:18,170 INFO [jeeves.request] - HTML Request (from 140.172.184.34) : /geonetwork/srv/en/metadata.update.validate
2009-04-09 14:44:18,170 DEBUG [jeeves.request] - Method : POST
2009-04-09 14:44:18,170 DEBUG [jeeves.request] - Content type : application/x-www-form-urlencoded
2009-04-09 14:44:18,170 DEBUG [jeeves.request] - Accept : text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2009-04-09 14:44:18,175 INFO [jeeves.service] - Dispatching : metadata.update.validate
2009-04-09 14:44:18,178 DEBUG [jeeves.service] - -> parameters are :
<request>
<_73>LiDAR DEM Quality Control Report. The accuracy of a LiDAR DEM is estimated by determining the root mean square error (RMSE). RMSE is the square root of the average of the set of squared differences between dataset co-ordinate values and co-ordinate values from an independent source of higher accuracy for identical points. If those differences are normally distributed and average zero, 95 percent of any sufficiently large sample should be less than 1.96 times the RMSE. Therefore 15-centimeter RMSE is often referred to as &quot;30-centimeter accuracy at the 95-percent confidence level&quot;. Following that convention, the vertical accuracy of any DEM is defined as 1.96 times the RMSE of linearly interpolated elevations in the DEM, as compared with known elevations from high-accuracy test points. DEMs should have a maximum RMSE of 15 centimeters, which is roughly equivalent to 1-foot accuracy. Field verification of the vertical accuracy of this DEM to ensure that the 15-centimeter RMSE requirement was satisfied for all major vegetation categories that were predominate a) Bare-earth and low grass (plowed fields, lawns, golf courses); b) High grass and crops (hay fields, cornfields, wheat fields); c) Brush lands and low trees (chaparrals, mesquite, mangrove swamps); d) Fully covered by trees (hardwoods, evergreens, mixed forests); and e) Urban areas (high, dense man-made structures). An even distribution of sample points throughout each category area evaluated was collected and not grouped in a small subarea. The RMSE calculated from a sample of test points is not the RMSE of the DEM. The calculated value may be higher or it may be lower than that of the DEM. Confidence in the calculated value increases with the number of test points. If the errors (lack of accuracy) associated with the DEM are normally distributed and unbiased, the confidence in the calculated RMSE can be determined as a function of sample size. Similarly, the sample RMSE necessary to obtain 95-percent confidence that the DEM RMSE is less than 15 centimeters can also be determined as a function of sample size. For each major vegetation category, a sample of points was tested to show the test points have an RMSE less than where n is the number of test points in the sample. A minimum of 20 test points for each major vegetation category was identified. Therefore, a minimum of 100 test points was selected for the five major vegetation categories. The test points were to be selected in areas to evaluate DEM accuracy under trees and in vegetation representative of the study area. The PDOP during the LiDAR data collection was consistently less than 3.0 and was determined to be of no issue. Test points on sloping or irregular terrain would be unreasonably affected by the linear interpolation of test points from surrounding DEM points and, therefore, were not selected. Test points were collected by RTK (Real-Time Kinematic) GPS techniques. Three thousand Two Hundred and Sixty points were collected in total covering each of the five main categories of ground cover in the survey areas. Furthermore, six of the forty-eight control monuments falling within the project area and installed as part of the survey network were used as a further check. All RMSE calculations were performed on the bare-earth, orthometric surface. Results The comparisons between each validation point and the LiDAR DEM are shown in Appendix A. The comparisons between each control point and the LiDAR DEM are shown in Appendix B. The RMSE was determined for the project area. US Survey Feet Meters Average dz 0.144 0.044 Average magnitude</_73>
</request>
2009-04-09 14:44:18,544 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
<message />
<class>StackOverflowError</class>
<stack>
<at class="com.sun.org.apache.xerces.internal.impl.xpath.regex.RegularExpression" file="RegularExpression.java" line="1914" method="matchString" />
<at class="com.sun.org.apache.xerces.internal.impl.xpath.regex.RegularExpression" file="RegularExpression.java" line="1940" method="matchString" />
</stack>
<request>
<language>en</language>
<service>metadata.update.validate</service>
</request>
</error>
2009-04-09 14:44:18,545 INFO [jeeves.service] - -> dispatching to error for : metadata.update.validate
