[GeoNetwork-devel] GeoNetwork 2.6.0 on Windows 7 and Java 6
Hello,
I am having a problem installing GeoNetwork on my Windows 7 PC with Java 6. I’ve tried both the .exe windows installer and the .jar and get the same results: the installation completes without error but I cannot start the server. I’m using the default Jetty and McKoiDB. Perhaps GeoNetwork cannot yet run on Java 6?
Thanks, Bob
Bob Nutsch
GIS Coordinator
State of North Dakota
Phone: (701) 328-3212
bnutsch@anonymised.com…
Twitter: @BobNutsch
www.nd.gov/gis
NDGIS Users Conference Oct. 11-13, 2011 !!
Hi Bob
Can you provide more information? The log files in jetty/logs folder should have more information about the problem.
I normally work with Java 1.6, so that should not be the problem.
Jose García
On Mon, Nov 15, 2010 at 5:34 PM, Nutsch, Bob D. <bnutsch@anonymised.com> wrote:
Hello,
Thanks, Bob
Bob Nutsch
GIS Coordinator
Twitter: @BobNutsch
www.nd.gov/gis
Centralized Desktop Delivery: Dell and VMware Reference Architecture
Simplifying enterprise desktop deployment and management using
Dell EqualLogic storage and VMware View: A highly scalable, end-to-end
client virtualization framework. Read more!
http://p.sf.net/sfu/dell-eql-dev2dev
GeoNetwork-devel mailing list
Hello Jose,
Thanks for the email. There is nothing in the jetty/logs folder other than the ‘archive’ folder.
Not sure if this helps, but when trying to manually start the GN with the start-geonetwork.bat I see the following:
bin>start-geonetwork.bat
bin>cd …\jetty
jetty>del logs*request.logCould Not Find C:\Program Files (x86)\geonetwork\jetty\logs*request.log
jetty>del logs\output.log Could Not Find C:\Program Files (x86)\geonetwork\jetty\logs\output.log
jetty>move logs\geonetwork.log.* logs\archive A duplicate file name exists, or the file cannot be found.
jetty>move logs\intermap.log.* logs\archive A duplicate file name exists, or the file cannot be found.
jetty>move logs\geoserver.log.* logs\archive A duplicate file name exists, or the file cannot be found.
jetty>rem try changing the Xmx parameter if your machine has little RAM
jetty>rem java -Xms48m -Xmx256m -XX:MaxPermSize=128m -XX:CompileCommandFile=hotspot_compiler -Dmime-mappings=…\web\geonetwork\WEB-INF\mime-types.properties -DSTOP.PORT=8079 -DSTOP.KEY=geonetwork -jar start.jar …\bin\jetty.xml
jetty>rem if you want to hide the dos window when GeoNetwork is started,
jetty>rem comment out the next line and comment the last line
jetty>java -Xms48m -Xmx512m -Xss2M -XX:MaxPermSize=128m -XX:CompileCommandFile=hotspot_compiler -Dmime-mappings=…\web\geonetwork\WEB-INF\mime-types.properties -DSTOP.PORT=8079 -Djava.awt.headless=true -DSTOP.KEY=geonetwork -jar start.jar …\bin\jetty.xml’java’ is not recognized as an internal or external command,operable program or batch file.
jetty>rem start javaw -Xms48m -Xmx512m -Xss2M-XX:MaxPermSize=128m -XX:CompileCommandFile=hotspot_compiler -Dmime-mappings=…\web\geonetwork\WEB-INF\mime-types.properties -DSTOP.PORT=8079 -Djava.awt.headless=true -DSTOP.KEY=geonetwork -jar start.jar …\bin\jetty.xml
Regards, Bob
From: jose garcia [mailto:josegar74@anonymised.com]
Sent: Monday, November 15, 2010 1:13 PM
To: Nutsch, Bob D.
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] GeoNetwork 2.6.0 on Windows 7 and Java 6
Hi Bob
Jose García
Hello,
Thanks, Bob
Bob Nutsch
GIS Coordinator
Twitter: @BobNutsch
www.nd.gov/gis
Is there a permissions problem-- your login may not have authority to create/move the log files in C:\Program Files (x86)…
steve
Stephen M. Richard
Arizona Geological Survey
416 W. Congress St., #100
Tucson, Arizona, 85701
USA
phone: 520 209-4127
AZGS Main: (520) 770-3500.  FAX: (520) 770-3505
email: [steve.richard@anonymised.com](mailto:steve.richard@anonymised.com)
Hi Steve,
I don’t believe so as I’m able to install software there and create a file with a text editor.
Thanks, Bob
From: Stephen M Richard [mailto:steve.richard@anonymised.com]
Sent: Monday, November 15, 2010 2:01 PM
To: geonetwork-devel@lists.sourceforge.net
steve
On 11/15/2010 12:31 PM, Nutsch, Bob D. wrote:
Hello Jose,
bin>cd …\jetty
Regards, Bob
To: Nutsch, Bob D.
snip…
Stephen M. Richard
USA
phone: 520 209-4127
Hi Bob,
Looking at the output of start-geonetwork.bat its saying:
'java' is not recognized as an internal or external command,operable program or batch file.
So perhaps its not finding 'java'. You may need to add the directory where
the java binary is to your windows PATH.
HTH
Andrew
----- Original Message ----- From: Nutsch, Bob D.
To: jose garcia
Sent: Tuesday, November 16, 2010 06:31
Hello Jose,
Thanks for the email. There is nothing in the jetty/logs folder other than the 'archive' folder.
bin>cd ..\jetty
jetty>del logs\*request.log*Could Not Find C:\Program Files (x86)\geonetwork\jetty\logs\*request.log*
jetty>rem java -Xms48m -Xmx256m -XX:MaxPermSize=128m -XX:CompileCommandFile=hotspot_compiler -Dmime-mappings=..\web\geonetwork\WEB-INF\mime-types.properties -DSTOP.PORT=8079 -DSTOP.KEY=geonetwork -jar start.jar ..\bin\jetty.xml
jetty>java -Xms48m -Xmx512m -Xss2M -XX:MaxPermSize=128m -XX:CompileCommandFile=hotspot_compiler -Dmime-mappings=..\web\geonetwork\WEB-INF\mime-types.properties -DSTOP.PORT=8079 -Djava.awt.headless=true -DSTOP.KEY=geonetwork -jar start.jar ..\bin\jetty.xml'java' is not recognized as an internal or external command,operable program or batch file.
jetty>rem start javaw -Xms48m -Xmx512m -Xss2M-XX:MaxPermSize=128m -XX:CompileCommandFile=hotspot_compiler -Dmime-mappings=..\web\geonetwork\WEB-INF\mime-types.properties -DSTOP.PORT=8079 -Djava.awt.headless=true -DSTOP.KEY=geonetwork -jar start.jar ..\bin\jetty.xml
Regards, Bob
To: Nutsch, Bob D.
Hi Bob
Jose García
Hello,
I am having a problem installing GeoNetwork on my Windows 7 PC with Java 6. I've tried both the .exe windows installer and the .jar and get the same results: the installation completes without error but I cannot start the server. I'm using the default Jetty and McKoiDB. Perhaps GeoNetwork cannot yet run on Java 6?
Thanks, Bob
Bob Nutsch
GIS Coordinator
Twitter: @BobNutsch
www.nd.gov/gis
Hello Andrew,
DOH! That was my problem, thanks for the catch! All is well now.
Regards, Bob
-----Original Message-----
Sent: Monday, November 15, 2010 3:39 PM
To: Nutsch, Bob D.
Hi Bob,
batch file.
HTH
Andrew
To: jose garcia
Hello Jose,
'archive' folder.
bin>cd ..\jetty
jetty>rem
jetty>rem start
Regards, Bob
To: Nutsch, Bob D.
Hi Bob
Jose García
Hello,
6?
Thanks, Bob
Bob Nutsch
GIS Coordinator
Twitter: @BobNutsch
www.nd.gov/gis
