Hi there,
I have noted that automatic thumbnail creation does not work when harvesting, did you have any ideas on how to fix this?
cheers
peter
Hi there,
cheers
peter
2015-07-20 0:24 GMT+02:00 Peter Van Dijk <upploadds@anonymised.com>:
Hi there,
Was it working on 3.0.0 ?
If you don’t provide the WMS to test with and the harvester configuration you’re using, we can’t really try to reproduce.
So far, the feature works properly using http://geoservices.brgm.fr/geologie WMS1.3 for example.
Cheers.
Francois
cheers
peter
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
GeoNetwork-devel mailing list
Ok thanks Francois, i’ll test if i can harvest with thumbnails from that server and let you know.
i couldn’t get it to work in 3.00 but was concentrating on other things.
cheers
Hi Francois,
I have tested wms 1.3 harvest and i can harvest the records but not create thumbnails. images look to be broken.
I’ll have a closer look at the file structure in the morning, to see if any images were actually created on the server.
cheers
On Wed, Jul 22, 2015 at 7:53 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi there,
Cheers.
Francois
cheers
peter
Hi Francois,
I have an alias to my internal dns do that the server is running as it would externally and i can now see the thumbnails as created when harvesting the server you included.
I will test harvesting from my geoserver again and let you know the outcome.
thanks for your help with this
cheers
On Thu, Jul 23, 2015 at 5:53 PM, Peter Van Dijk <upploadds@anonymised.com> wrote:
Hi Francois,
I’ll have a closer look at the file structure in the morning, to see if any images were actually created on the server.cheers
Hi there,
Cheers.
Francois
cheers
peter
Hi Francois,
I have investigated the automatic thumbnail creation and have it working now.
The reason it was failing is because of the url being used to access the server.
I was including the full version and getcapabilities request eg: service=wms&version=1.3.0&request=GetCapabilities
which works ok to harvest the records but causes the thumbnails to fail.
I shortened the url down to ows? and everything is working fine.
cheers
On Fri, Jul 24, 2015 at 3:47 PM, Peter Van Dijk <upploadds@anonymised.com> wrote:
Hi Francois,
I will test harvesting from my geoserver again and let you know the outcome.thanks for your help with this
cheers
Hi Francois,
Hi there,
Cheers.
Francois
cheers
peter
