On Thu, Oct 8, 2015 at 4:49 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
For now, committed the fix and added @Ignore to the test indicated by Emanuele.
Jose García
GeoNetwork-devel mailing list
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Oct 8, 2015 at 4:36 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
Has been this fixed in any way? I removed the wro cache and rebuild the project and getting the error with the UI, not very nice.
Does any other get the same problem?
Jose García
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
M: +31 (0)655 818332
Please consider the environment before printing this email.
On Wed, Sep 30, 2015 at 10:29 AM, María Arias de Reyna <delawen@…31…> wrote:
Yes, please. Tests are not useful if they are incompatible with GeoNetwork working fine.
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
On Tue, Sep 29, 2015 at 7:10 PM, Emanuele Tajariol <etj@anonymised.com> wrote:
Removing the import works fine. Can I commit the change or can cause any
side effect?
Removing the import will break the build of /web (GeoNetwork Web module).
This will be the result:
| Wro4jJsCssCompilationTest.testCssCompilation:84->testResourcesOfType:131
|The following errors were encountered while compiling the CSS resources
|* Group Name: ellipsis
| * Resources: ellipsis
| - file:/home/geosol/prj/gn/3/core-geonetwork/web-|
ui/src/main/resources/catalog/style/ellipsis.less
| * Error Message:
| > Could not compile less. 2 error(s) occurred:
| > ERROR 4:11 The variable “@ellipsis-height” was not declared.
| > ERROR 13:11 The variable “@ellipsis-height” was not declared.
| at org.junit.Assert.fail(Assert.java:93)
| at org.junit.Assert.assertTrue(Assert.java:43)
| at
org.fao.geonet.wro4j.Wro4jJsCssCompilationTest.testResourcesOfType(Wro4jJsCssCompilationTest.java:131)
| at
org.fao.geonet.wro4j.Wro4jJsCssCompilationTest.testCssCompilation(Wro4jJsCssCompilationTest.java:84)
There’s an error in the import dependencies of the various less files I guess.
Shall we @Ignore this test as well? No point in having one test passing, but
gn not running
Emanuele
Alle 18:41:15 di Tuesday 29 September 2015, Jose Garcia ha scritto:
Hi Emanuele
side effect?
Jose García
On Tue, Sep 29, 2015 at 6:18 PM, Emanuele Tajariol <etj@anonymised.com>
wrote:
Hi Jose,
it may be related to this:
https://github.com/geonetwork/core-
geonetwork/commit/29b3d651adf5a24a3fee707d69356d9d02a19c97#diff-
bc14b53beeed53edab6b6b906609506cR1
Try removing the import.
Emanuele
Alle 16:30:31 di Tuesday 29 September 2015, Jose Garcia ha scritto:
Hi
I updated to the latest revision of 3.0.x, but when trying to access
the search results page, I’m getting this exception and the page is
not rendered:
2015-09-29 16:24:05,929 WARN [geonetwork.resources] - Resource not
found images/logos/favicon.png, default resource returned:
/images/logos/favicon.png
2015-09-29 16:24:06,013 WARN [geonetwork.resources] - Resource not
2015-09-29 16:26:12.444:WARN:oejs.ServletHandler:Error for
/geonetwork/static/gn_search_default.css
java.lang.StackOverflowError
at java.io.UnixFileSystem.getBooleanAttributes0(Native Method)
at java.io.UnixFileSystem.getBooleanAttributes(UnixFileSystem.java:242)
at java.io.File.isDirectory(File.java:843)
at
sun.net.www.protocol.file.FileURLConnection.connect(FileURLConnection.java:
at
sun.net.www.protocol.file.FileURLConnection.getInputStream(FileURLConnect
io
n.java:188)
at
ro.isdc.wro.model.resource.locator.UrlUriLocator.locate(UrlUriLocator.java:
at
ro.isdc.wro.model.resource.locator.factory.InjectableUriLocatorFactoryDec
or
ator.locate(InjectableUriLocatorFactoryDecorator.java:37)
at
ro.isdc.wro.model.resource.support.change.ResourceWatcher.isChanged(Resou
rc
eWatcher.java:281)
I have try in debug and non debug modes and cleaning up the wro cache,
but
no success.
Any idea what can be causing this?
Jose García
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
mob: +39 380 2116282
Technical Lead
