Hi Maria,
I tried to run it from the web directory but I still get issues. Here’s is the message:
Any suggestion?
De : María Arias de Reyna [mailto:delawen@anonymised.com]
Envoyé : jeudi 13 novembre 2014 09:19
À : Hamdi KACEM
Cc : Devel geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Geonetwork 3.0
Hi Hamdi,
You are right, the jetty:run command have to be made from the “web” directory, not the root folder. Does it work now?
On Thu, Nov 13, 2014 at 9:15 AM, Hamdi KACEM <hamdi.kacem@anonymised.com…> wrote:
I end up at this step without being able to run geonetwork. Below the messages:
Anyone can support?
Regards.
De : Florent Gravin [mailto:florent.gravin@anonymised.com]
Envoyé : mercredi 12 novembre 2014 19:14
À : Hamdi KACEM
Cc : geonetwork-devel@lists.sourceforge.net
Well you need to find a way to set MAVEN_OPTS global variable on your system.
Maybe add a environnement variable into system settings wizard and restart your cmd. Or check how to set it into CMD relating to your OS.
good luck
On Wed, Nov 12, 2014 at 6:49 PM, Hamdi KACEM <hamdi.kacem@anonymised.com…> wrote:
Hi Florent,
Should I copy and execute that line in the same repository (geonetwork repository)?
This is because I’ve tried that and got the following message:
Envoyé : mercredi 12 novembre 2014 18:18
À : Hamdi KACEM
Cc : María Arias de Reyna; geonetwork-devel@lists.sourceforge.net
As written in the cmd window, you have to add MAVEN_OPTS for memory settings.
Copy the line under Cmd/Powershell in your command line, then try the build again.
On Wed, Nov 12, 2014 at 6:14 PM, Hamdi KACEM <hamdi.kacem@anonymised.com…> wrote:
Hi Maria,
Thanks for your answer.
I’ve followed your instructions, however the build task failed. Below, you can find the terminal message.
Do you know what’s the issue in there?
Best Regards,
Envoyé : mercredi 12 novembre 2014 12:58
À : Hamdi KACEM
On Wed, Nov 12, 2014 at 12:36 PM, Hamdi KACEM <hamdi.kacem@anonymised.com…> wrote:
Can anyone help me to deploy Geonetwork 3.0 on my windows desktop. I would like to have an idea about the new figures/topics coming up with this new stable version.
In fact, I have downloaded from github the entire repository into my Apache server but I didn’t find how to launch the application.
Looking forward to receiving your support!
Hi Hamdi,
To be able to run geoNetwork, you have to install maven on your computer:
http://maven.apache.org/guides/getting-started/windows-prerequisites.html
Once you have maven, you can run it on the root folder of the repository:
“mvn package install -DskipTests”
That will compile and build geoNetwork. To test it, you can run again maven on the root folder:
“mvn jetty:run”
And geoNetwork will be waiting for you on http://localhost:8080/geonetwork
Good luck,
María.
Best regards,
Hamdi KACEM
Ingénieur Géomaticien
ST2i - Groupe STUDI - Tunisie
Adresse : Avenue du Dollar Résidence Sidi Mansour III Bloc A – 1053 Les Berges du Lac – TUNISIE
Tél : +216 71 195 300 poste (205)
Fax : +216 71 195 301
www.st2i.com.tn
www.studi.com.tn
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://pubads.g.doubleclick.net/gampad/clk?id=154624111&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Florent Gravin
Camptocamp - Chambéry
0479444492
Florent Gravin
0479444492
