Hi there,
I am wishing to remove the first image for a layer, on the metadataview right hand column
I think i should be able to have only the first image appear by taking the first result for the grid but am unsure which file, files i need to alter.
Should i alter the function or the html template?
Any pointers would be greatly appreciated.
cheers
Hi Francois,
I have made some adjustments in my local version of recordview.html that have had the desired result.
I replaced this code from line 405
overview
<img data-gn-img-modal=“md”
class=“gn-img-thumbnail img-thumbnail”
alt=“{{img.label}}”
data-ng-src=“{{img.url}}”/>
With this adjusted code
Hi Francois,
I replaced the code from line 405 with adjusted code as included in the screenshot.
I have also attached a screenshot of the gui with the change, much nicer in my opinion with just the single overview image.
I have also made sure to adjust so that modal popup is still functional etc.
cheers and thanks again for your help
Peter
(attachments)
On Fri, Sep 4, 2015 at 5:05 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi
2015-09-04 5:37 GMT+02:00 Alginnon Games <upploadds@anonymised.com>:
Hi there,
Probably here
https://github.com/geonetwork/core-geonetwork/blob/3.0.x/web-ui/src/main/resources/catalog/views/default/templates/recordView.html#L405
Francois
cheers
GeoNetwork-devel mailing list
