[Geonetwork-devel] Geonetwork alpha install (root element problem)
I’ve been trying to install the latest version of geonetwork (2.1.0_alpha_1) ) from CVS in order
to get access to the CSW functionality.
Had a couple of minor glitches. Script setup/sql/create-db-mckoi.sql attempts to create table
‘Settings’ twice and the unique constraint on uuid on the Metadata table is violated during loading. Fixed those but hit a more serious problem. During installation there is error message “No root element set”.
I’ve traced this a bit - its getting thrown in the last line of method updateFixedInfo in class org.fao.geonet.apps.setup.Setup.java - where you are trying to do an xsl transformation on the metadata. The record that’s failing has ID 16 and iso19139 schema.
I hit the same problem last week but I noticed that in response to a question about the root element of an iso19139 document last tuesday Andrea has updated the root element of this record to DS_Dataset. Was hoping that might have addressed my problem but doesn’t seem to have helped.
I’d appreciate any help you can give as we (EDINA) haven’t yet managed to build a version with the new CSW code.
Many thanks
Andrew Robson
Hi Andrew,
many thanks for your feedback: I'm working on the harvesting so I haven't fixed
the installer yet. I will address these points ASAP so you can work. I will try to
have a working/installable geonetwork so that others can test it.
I've been trying to install the latest version of geonetwork (2.1.0_alpha_1)
) from CVS in order
setup/sql/create-db-mckoi.sqlattempts to create table
'Settings' twice and the unique constraint on uuid on the Metadata table is
installation there is error message "No root element set".
I've traced this a bit - its getting thrown in the last line of method
are trying to do an xsl transformation on the metadata. The record that's
might have addressed my problem but doesn't seem to have helped.
I'd appreciate any help you can give as we (EDINA) haven't yet managed to
Many thanks
Andrew Robson
