Hi Cameron,
As said by Mathieu, I worked on prototyping integration of Openlayers
into GeoNetwork one year ago when Intermap was not yet really embed into
the catalogue ... making some change into GeoNetwork and the georss
layer in Openlayers in order to display bounding box georss feeds (with
a symbol proportional to the number of results on the upper corner). For
GeoNetwork, I should be able to provide the code, but GeoNetwork was a
2.1 alpha version last year ... For OpenLayers the patch has been
submitted to the trac.
See this thread from the mailing list:
http://www.nabble.com/geonetwork-beta-and-openlayers-tt9868332.html#a9868332
(demonstration website is still alive).
Concerning migrating from an Intermap to an Openlayers webmap interface,
this will require more works and analysis I guess. Intermap is now
providing advanced functionnalities (Pdf map, WMC support, Email map,
Annotation, ...). All these are not available in Openlayers and not or
partial in MapFish (at least for the time being).
I don't really know how far you have to go in the webmap interface for
your project? If you have to only set up the bounding box parameter
using OpenLayers, this is easy. If you need to have the same level of
functionnalities than in Intermap ... more work required.
Maybe in this discussion, we should decide if we should plan for
migration of Intermap? For which release? Which resources are
available ?
Ciao. Francois
On mer, 2008-05-21 at 12:01 +0200, Mathieu Coudert wrote:
Hi Cameron,
It is neither in OpenLayers svn nor in GeoNetwork svn.
Maybe François-Xavier you have any idea about how to make this code
available?
On Tue, May 20, 2008 at 10:06 PM, Cameron Shorter
<cameron.shorter@anonymised.com> wrote:
Thank you Mathieu for responding.
Where is the functionality that you are describing?
Is it in the Geonetwork svn, or maybe Openlayers svn?
Hi Cameron,
Indeed It is true that we had a look on it. We
integrated Openlayers in Geonetwork in order to
perform geographical search, defining bbox criteria
using Openlayers. We also looked into the georss
search in Geonetwork, displaying results in
Openlayers.
For specific needs, we implemented Openlayers as WMS
viewer in Geosource (GeoNetwork including profil for
France).
Openlayers, at this time, does not provide Intermap
advanced functionnality such as PDF printing, web map
context and map annotations, this is a current
limitation.
Concerning Mapfish, there is no plan to integrate it
as a GUI for Geonetwork but interaction between both
will probably be developed in the coming month.
Mathieu
On Tue, May 20, 2008 at 2:23 PM, Cameron Shorter
<mailto:cameron.shorter@anonymised.com>> wrote:
Openlayers developers,
LISAsoft has been hired to improved the User
Interface for Geonetwork
and we will be kicking off the project tomorrow.
Jeroen tells me that Camp2Camp has already been
looking into
building a
GUI for Geonetwork. Is this true?
If so, what is the state of this Camp2Camp work?
Where are you up
to? Do
you have anything that we can contribute to or
build upon?
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source
Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
Dev mailing list
Dev@anonymised.com <mailto:Dev@anonymised.com>
http://openlayers.org/mailman/listinfo/dev
Mathieu Coudert
mcoudert@anonymised.com <mailto:mcoudert@anonymised.com>
Cameron Shorter
Commercial Support for Geospatial Open Source Solutions
Defy all challenges. Microsoft(R) Visual Studio 2008.
_______________________________________________ GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-devel GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Francois Xavier Prunayre
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)6 34 11 71 75
http://www.camptocamp.com
francois-xavier.prunayre@anonymised.com
