Bugs item #1328744, was opened at 2005-10-17 10:22
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533368&aid=1328744&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: None
Group: None
Status: Open
Resolution: None
Priority: 5
Submitted By: Gregory Roberts (geroberts62)
Assigned to: Nobody/Anonymous (nobody)
Summary: Problem working with Oracle 10g
Initial Comment:
I've installed the v2.0b4 with the jdbc for Oracle 10g
on an XP Pro system. So far all it allows me to do is
login.
I have verified that the tables have been created in
Oracle and that the data has been loaded. I am able to
log in, but that is all that I am able to do.
It will not return any data from the database, nor will
it allow me to create any new metadata. It even fails
when I try to create a new user.
The Template and Group list boxes will not populate, so
I cannot create any new metadata.
When I attempt to creat a new user, I receive the
following error:
The requested operation could not be performed.
For input string: "1.0"
For a new group I receive:
For input string: "2.0"
Also, here are the errors that are present when I start the
GeoNetwork service. These are from the jetty.log:
0 [main] WARN com.k_int.hss - Unable to locate
collection directory service
javax.naming.NotContextException: Services is not a
subcontext
2005-10-10 11:01:45 | - Access manager...
2005-10-10 11:01:45 | - Data manager...
2005-10-10 11:01:46 | Raised exception while starting appl
handler. Skipped.
2005-10-10 11:01:46 | Handler :
org.fao.geonet.Geonetwork
2005-10-10 11:01:46 | Exception :
java.lang.NumberFormatException: For input string:
"1.0"
2005-10-10 11:01:46 | Message : For input string:
"1.0"
2005-10-10 11:01:46 | Stack :
"1.0"
at java.lang.NumberFormatException.forInputString(Unknown
Source)
at java.lang.Integer.parseInt(Unknown Source)
at java.lang.Integer.<init>(Unknown Source)
Any and all help would be greatly appreciated!
