[Geonetwork-devel] [ geonetwork-Bugs-1385100 ] Calendar does not work properly on IE
Bugs item #1385100, was opened at 2005-12-19 12:33
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533368&aid=1385100&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Editor
Group: v2.0.0
Status: Open
Resolution: None
Priority: 9
Submitted By: Jeroen Ticheler (ticheler)
Assigned to: Nobody/Anonymous (nobody)
Summary: Calendar does not work properly on IE
Initial Comment:
The pop up calendar does not read and write the value
from the corresponding text field, making it impossible
to edit the date value.
The clear function works.
