[GeoNetwork-devel] [ geonetwork-Bugs-1651259 ] geonet:info element on remote results causes confusion
Bugs item #1651259, was opened at 2007-02-03 06:39
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533368&aid=1651259&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Search/ Distributed search
Group: None
Status: Open
Resolution: None
Priority: 5
Private: No
Submitted By: Nobody/Anonymous (nobody)
Assigned to: Nobody/Anonymous (nobody)
Summary: geonet:info element on remote results causes confusion
Initial Comment:
geonet:info element on results returned from searching a remote geonetwork confuses presentation of results because it takes priority over geonet:info element generated by local geonetwork.
geonetwork 2.0.3
reproduce by searching your own geonetwork (localhost:2100) together with a remote Z39.50 site using the remote search function - presentation of results is confused by the geonet:info element which relates to local geonetwork.
Fix by removing any geonet:info elements from results before adding in geonet:info relevant to local geonetwork.
Affected file is: org/fao/geonet/kernel/search/Z3950Searcher.java
in present method
simon@anonymised.com
