Bugs item #1651262, was opened at 2007-02-03 06:45
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533368&aid=1651262&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Editor
Group: None
Status: Open
Resolution: None
Priority: 5
Private: No
Submitted By: Nobody/Anonymous (nobody)
Assigned to: Nobody/Anonymous (nobody)
Summary: templates in metadata.create.form not indexed properly
Initial Comment:
Templates cannot be retrieved because metadata does not appear to be indexed properly for lucene to pick up which metadata records are templates and which are not.
Symptom: end up with blank list of templates in the metadata creation pull down despite being a member of group that can view the template!
Fix: force indexing of metadata in DataManager constructor.
Affected file: org/fao/geonet/kernel/DataManager.java in DataManager constructor.
simon@anonymised.com
