[GeoNetwork-devel] [ geonetwork-Bugs-1655563 ] NumberFormatException: 0:0:0:0:0:0:0:1%0
Bugs item #1655563, was opened at 2007-02-08 22:40
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533368&aid=1655563&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: None
Group: None
Status: Open
Resolution: None
Priority: 5
Private: No
Submitted By: Tore Halset (halset)
Assigned to: Nobody/Anonymous (nobody)
Summary: NumberFormatException: 0:0:0:0:0:0:0:1%0
Initial Comment:
Installed geonetwork 2.0.2 server on a mac to try it out (newbie alert). Logging in as administrator did not work. Looks like geonetwork has problems we IPv6 localhost address.
Here is the stacktrace.
2007-02-08 22:32:22 | [main.home] Exception executing gui service : java.lang.NumberFormatException: For input string: "0:0:0:0:0:0:0:1%0"
2007-02-08 22:32:22 | [main.home] (C) Stack trace is :
        at java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
        at java.lang.Integer.parseInt(Integer.java:456)
        at java.lang.Integer.parseInt(Integer.java:497)
        at org.fao.geonet.kernel.AccessManager.getAddress(AccessManager.java:247)
        at org.fao.geonet.kernel.AccessManager.getUserGroups(AccessManager.java:177)
        at org.fao.geonet.kernel.search.LuceneSearcher.computeQuery(LuceneSearcher.java:158)
        at org.fao.geonet.kernel.search.LuceneSearcher.search(LuceneSearcher.java:74)
        at org.fao.geonet.guiservices.metadata.GetRandom.exec(GetRandom.java:89)
        at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
        at jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.java:120)
        at jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.java:105)
        at jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.java:574)
        at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:381)
        at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:614)
        at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:170)
        at jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:110)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:616)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:427)
        at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:473)
        at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:568)
        at org.mortbay.http.HttpContext.handle(HttpContext.java:1565)
        at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:635)
        at org.mortbay.http.HttpContext.handle(HttpContext.java:1517)
        at org.mortbay.http.HttpServer.service(HttpServer.java:954)
        at org.mortbay.http.HttpConnection.service(HttpConnection.java:816)
        at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:983)
        at org.mortbay.http.HttpConnection.handle(HttpConnection.java:833)
        at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:244)
        at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:357)
        at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:534)
