Bugs item #1661979, was opened at 2007-02-16 23:29
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533368&aid=1661979&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Web configuration
Group: v2.1.0
Status: Open
Resolution: None
Priority: 7
Private: No
Submitted By: Jeroen Ticheler (ticheler)
Assigned to: Andrea Carboni (acarboni)
Summary: Save a harvesting configuration
Initial Comment:
Further on while adding the geonetwork.csi.cgiar.org node, I get the following when trying to save. Saving fails at that point:
2007-02-16 23:21:01,721 INFO [jeeves.request] - HTML Request (POST) : /geonetwork/srv/en/xml.harvesting.add
2007-02-16 23:21:01,735 INFO [jeeves.service] - Dispatching : xml.harvesting.add
2007-02-16 23:21:01,735 DEBUG [jeeves.service] - -> parameters are :
2007-02-16 23:21:01,735 DEBUG [jeeves.service] - site =
2007-02-16 23:21:01,735 DEBUG [jeeves.service] - searches =
2007-02-16 23:21:01,736 DEBUG [jeeves.service] - options =
2007-02-16 23:21:01,736 DEBUG [geonetwork.harvest-man] - Adding harvesting node :
<node id="" name="CGIAR GeoNetwork" type="geonetwork">
<site>
<host>geonetwork.csi.cgiar.org</host>
<port>80</port>
<servlet>geonetwork</servlet>
<account>
<use>false</use>
<username />
<password />
</account>
</site>
<searches>
<search>
<freeText />
<title />
<abstract />
<keywords />
<digital>false</digital>
<hardcopy>false</hardcopy>
<siteId>mySiteId</siteId>
</search>
</searches>
<options>
<every>2880</every>
<createGroups>false</createGroups>
<oneRunOnly>false</oneRunOnly>
</options>
</node>
2007-02-16 23:21:02,018 ERROR [jeeves.service] - Exception when executing service
2007-02-16 23:21:02,019 ERROR [jeeves.service] - (C) Exc : java.lang.NullPointerException
2007-02-16 23:21:02,027 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
<exception>
<message />
<class>NullPointerException</class>
<stack>java.lang.NullPointerException
at org.fao.geonet.kernel.harvest.HarvestManager.addInfo(HarvestManager.java:217)
at org.fao.geonet.kernel.harvest.HarvestManager.get(HarvestManager.java:92)
at org.fao.geonet.services.harvesting.Get.exec(Get.java:60)
at jeeves.server.dispatchers.ServiceInfo.execService(ServiceInfo.java:238)
at jeeves.server.dispatchers.ServiceInfo.execServices(ServiceInfo.java:141)
at jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:376)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:610)
at jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:171)
at jeeves.server.sources.http.JeevesServlet.doPost(JeevesServlet.java:111)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:616)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:427)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:473)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1565)
at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:635)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1517)
at org.mortbay.http.HttpServer.service(HttpServer.java:954)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:816)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:983)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:833)
at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:244)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:357)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:534)</stack>
</exception>
<request>
<language>en</language>
<service>xml.harvesting.add</service>
</request>
</error>
