[GeoNetwork-devel] [ geonetwork-Bugs-1661983 ] Replacement of the sources.xml file
Bugs item #1661983, was opened at 2007-02-16 23:36
Message generated for change (Tracker Item Submitted) made by Item Submitter
You can respond by visiting:
https://sourceforge.net/tracker/?func=detail&atid=533368&aid=1661983&group_id=72096
Please note that this message will contain a full copy of the comment thread,
including the initial issue submission, for this request,
not just the latest update.
Category: Search/ Distributed search
Group: v2.1.0
Status: Open
Resolution: None
Priority: 5
Private: No
Submitted By: Jeroen Ticheler (ticheler)
Assigned to: Andrea Carboni (acarboni)
Summary: Replacement of the sources.xml file
Initial Comment:
In GN 2.1 the harvesting configuration is web based now. However, we still have a sources.xml that points for example to the logo's and also (in version 2.0) to the baseURL of that node. In v2.1 the baseURL is not part of the sources.xml . This would be OK if that, and the other required info like the logo would be available from the harvesting config database. Is that the case? Or will we have the sources.xml out of sync with the harvesting?
I have worked on updating the creation of links to the thumbnails and attribution logo's. For that I need the logo graphic name and the baseURL. Can that info be obtained from an XML service instead of from the static sources.xml file so we can replace the pointers to that/ update the XSLs?
Ciao,
Jeroen
