[GeoNetwork-devel] [GeoNetwork-commit] SF.net SVN: geonetwork:[6270] trunk
Hi Jose,
Am I missing something? I don't have
org.geonetwork.http.proxy.util.RequestUtil which is now imported in
WmcServlet? In fact I don't have directory org.geonetwork.http.proxy at
all...?
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
Hi Justin
The files are commited: https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/web/src/main/java/org/geonetwork/http/util/
Maybe a problem updating the SVN? Now seems a bit slow to access the SVN.
Also hudson builded correctly.
Jose Garcia
On Mon, Jul 12, 2010 at 12:24 PM, Justin Rowles (C) <Justin.Rowles@anonymised.com> wrote:
Hi Jose,
Am I missing something? I don’t have
WmcServlet? In fact I don’t have directory org.geonetwork.http.proxy at
all…?
Justin.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey’s behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Ordnance Survey
Romsey Road
Tel: 08456 050505
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/firsthttp://p.sf.net/sfu/sprint-com-first
GeoNetwork-devel mailing list
Dear Jose,
additional to the problem reported by Justin, I want to mention that trunk
6270 contains a lot of JavaScript changes. Unfortunately, the minified
javascript files in the webapp/scripts/lib directory are not part of the
SVN repository. After synchronizing a local GeoNetwork installation with the
current SVN repository you have to do a new JS build manually. This will be
very difficult if the file full.cfg is not up to date.
I appreciate if the minified JavaScript files in the lib directory could be
stored in the SVN repository such that they will be automatically updated by
a SVN synchronization.
Kind regards,
Jürgen
Dr. Jürgen Seib
Deutscher Wetterdienst
TI1/K - IT-Koordination
Frankfurter Strasse 135
63067 Offenbach
Tel.: +49(69)8062-2609
EMail: juergen.seib@anonymised.com
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Re-GeoNetwork-commit-SF-net-SVN-geonetwork-6270-trunk-tp5282371p5328619.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Juergen
For me is ok to store the minified files in SVN, if also ok for the other developers (we can check in next IRC meeting) .
The minified files are created automatically when executing mvn install and if not wrong full.cfg is not used since the change to maven, the pom file in web project uses yuicompressor-maven-plugin to create the minified files.
Jose Garcia
On Fri, Jul 23, 2010 at 9:15 AM, jseib <juergen.seib@anonymised.com> wrote:
Dear Jose,
Kind regards,
Jürgen
Dr. Jürgen Seib
63067 Offenbach
