Testing trunk, I'm always get a WARNING on startup about the XSLT
factory even if it looks to be ok.
2010-12-23 14:47:46,385 WARN [jeeves.engine] - Malformed definition
of XSLT transformer (in:
META-INF/services/javax.xml.transform.TransformerFactory).
2010-12-23 14:47:46,717 DEBUG [jeeves.engine] -
TransformerFactoryFactory: using transformer implementation
net.sf.saxon.IdentityTransformer
2010-12-23 14:47:46,718 INFO [jeeves.engine] - XSLT factory:
net.sf.saxon.Transfor
Francois
2010/12/22 <heikkidoeleman@anonymised.com>:
Revision: 7003
http://geonetwork.svn.sourceforge.net/geonetwork/?rev=7003&view=rev
Author: heikkidoeleman
Date: 2010-12-22 18:39:47 +0000 (Wed, 22 Dec 2010)
the warning comes from an incorrect check whether a string is null or empty (it is checking whether the string is not null or empty). Doesn’t impact program flow though, except for the incorrect message. Fixing it.
Thanks Francois !
On Thu, Dec 23, 2010 at 2:52 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Testing trunk, I’m always get a WARNING on startup about the XSLT
Francois
Revision: 7003
Learn how Oracle Real Application Clusters (RAC) One Node allows customers
to consolidate database storage, standardize their database environment, and,
should the need arise, upgrade to a full multi-node Oracle RAC database
without downtime or disruption
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-devel mailing list
