[GeoNetwork-devel] [GeoNetwork-commit] SF.net SVN: geonetwork:[8901]schemaPlugins/trunk/iso19135
Hi Simon,
Great work. Wish I had time to test all this new stuff with the
latest geonetwork trunk/ANZMEST.
Perhaps the <grg:versionNumber>/<gco:CharacterString> should be
"GCMD Science Keywords, Version 5.3.8" to show difference from
other lists e.g "GCMD Location Keywords"
Andrew
----- Original Message ----- From: <sppigot@anonymised.com>
To: <geonetwork-commit@lists.sourceforge.net>
Sent: Friday, March 23, 2012 1:44 AM
Subject: [GeoNetwork-commit] SF.net SVN: geonetwork:[8901]schemaPlugins/trunk/iso19135
Revision: 8901
         http://geonetwork.svn.sourceforge.net/geonetwork/?rev=8901&view=rev
Author: sppigot
Date: 2012-03-22 14:44:41 +0000 (Thu, 22 Mar 2012)
Log Message:
Add NASA GCMD Keywords version 5.3.8 in ISO19135 register format
Add XSLT to convert from keywords from format used by GCMD picker to 19135 register format
Added Paths:
   schemaPlugins/trunk/iso19135/convert/gcmdPickerXmlTo19135.xsl
schemaPlugins/trunk/iso19135/sample-data/nasa-gcmd-science-keywords-register.mef
Added: schemaPlugins/trunk/iso19135/convert/gcmdPickerXmlTo19135.xsl
--- schemaPlugins/trunk/iso19135/convert/gcmdPickerXmlTo19135.xsl (rev 0)
+++ schemaPlugins/trunk/iso19135/convert/gcmdPickerXmlTo19135.xsl 2012-03-22 14:44:41 UTC (rev 8901)
@@ -0,0 +1,272 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform&quot; version="2.0"
+ xmlns:gml="http://www.opengis.net/gml&quot;
+ xmlns:gco="http://www.isotc211.org/2005/gco&quot;
+ xmlns:gmx="http://www.isotc211.org/2005/gmx&quot;
+ xmlns:gmd="http://www.isotc211.org/2005/gmd&quot;
+ xmlns:grg="http://www.isotc211.org/2005/grg&quot;
+ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
+ xmlns:xlink="http://www.w3.org/1999/xlink&quot;
+ exclude-result-prefixes="#all">
+ <xsl:output method="xml" version="1.0" indent="yes"/>
+ <xsl:param name="uuid" select="generate-id()"/>
+ <xsl:variable name="versionDate">
+ <xsl:variable name="df">[Y0001]-[M01]-[D01]T[H01]:[m01]:[s01]</xsl:variable>
+ <xsl:value-of select="format-dateTime(current-dateTime(),$df)"/>
+ </xsl:variable>
+ <xsl:template match="/GCMD_KEYWORDS">
+ <xsl:element name="grg:RE_Register">
+ <xsl:namespace name="grg" select="'http://www.isotc211.org/2005/grg’"/>
+ <xsl:namespace name="gmd" select="'http://www.isotc211.org/2005/gmd’"/>
+ <xsl:namespace name="gco" select="'http://www.isotc211.org/2005/gco’"/>
+ <xsl:namespace name="xlink" select="'http://www.w3.org/1999/xlink’"/>
+ <xsl:attribute name="uuid"><xsl:value-of select="$uuid"/></xsl:attribute>
+ <xsl:attribute name="xsi:schemaLocation">http://www.isotc211.org/2005/grg/grg.xsd http://www.isotc211.org/2005/gmd/gmd.xsd http://www.isotc211.org/2005/gco/gco.xsd&lt;/xsl:attribute&gt;
+ <grg:name>
+ <gco:CharacterString>Global Change Master Directory Earth Science Keywords</gco:CharacterString>
+ </grg:name>
+ <grg:contentSummary>
+ <gco:CharacterString>Keywords organised in a hierarchy of topic, term and variable. There are 7 sets of keywords: data set, data services, data centers, locations, instrument/sensors, platforms/sources, and projects. This does not include the Climate Diagnostic keywords.</gco:CharacterString>
+ </grg:contentSummary>
+ <!-- Linkage to codelist catalog -->
+ <grg:uniformResourceIdentifier>
+ <gmd:CI_OnlineResource>
+ <gmd:linkage>
+ <gmd:URL>http://gcmd.nasa.gov/Resources/valids/archives/keyword_list.html&lt;/gmd:URL&gt;
+ </gmd:linkage>
+ </gmd:CI_OnlineResource>
+ </grg:uniformResourceIdentifier>
+ <!-- Operating Language -->
+ <grg:operatingLanguage>
+ <grg:RE_Locale>
+ <grg:name>
+ <gco:CharacterString>English</gco:CharacterString>
+ </grg:name>
+ <grg:language>
+ <gco:CharacterString>eng</gco:CharacterString>
+ </grg:language>
+ <grg:country>
+ <gco:CharacterString>USA</gco:CharacterString>
+ </grg:country>
+ <grg:characterEncoding>
+ <gmd:MD_CharacterSetCode codeListValue="utf8" codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_CharacterSetCode&quot;/&gt;
+ </grg:characterEncoding>
+ </grg:RE_Locale>
+ </grg:operatingLanguage>
+ <!-- Version - use this instead of dateOfLastChange -->
+ <grg:version>
+ <grg:RE_Version>
+ <grg:versionNumber>
+ <gco:CharacterString>GCMD Keywords, Version 5.3.8</gco:CharacterString>
+ </grg:versionNumber>
+ <grg:versionDate>
+ <gco:Date>2006</gco:Date>
+ </grg:versionDate>
+ </grg:RE_Version>
+ </grg:version>
+ <!-- Owner -->
+ <grg:owner>
+ <grg:RE_RegisterOwner>
+ <grg:name>
+ <gco:CharacterString>NASA</gco:CharacterString>
+ </grg:name>
+ <grg:contact xlink:href="#NASA_Contact"/>
+ </grg:RE_RegisterOwner>
+ </grg:owner>
+ <!-- Submitter -->
+ <grg:submitter>
+ <grg:RE_SubmittingOrganization>
+ <grg:name>
+ <gco:CharacterString>Various</gco:CharacterString>
+ </grg:name>
+ </grg:RE_SubmittingOrganization>
+ </grg:submitter>
+ <!-- containedItemClass - standard 19135 RE_RegisterItem -->
+ <grg:containedItemClass>
+ <grg:RE_ItemClass id="Item_Class">
+ <grg:name>
+ <gco:CharacterString>grg:RE_RegisterItem</gco:CharacterString>
+ </grg:name>
+ <grg:technicalStandard>
+ <gmd:CI_Citation>
+ <gmd:title>
+ <gco:CharacterString>ISO19135</gco:CharacterString>
+ </gmd:title>
+ <gmd:date>
+ <gmd:CI_Date>
+ <gmd:date>
+ <gco:Date>2005-10-15</gco:Date>
+ </gmd:date>
+ <gmd:dateType>
+ <gmd:CI_DateTypeCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode&quot; codeListValue="creation"/>
+ </gmd:dateType>
+ </gmd:CI_Date>
+ </gmd:date>
+ <gmd:edition>
+ <gco:CharacterString>First</gco:CharacterString>
+ </gmd:edition>
+ </gmd:CI_Citation>
+ </grg:technicalStandard>
+ </grg:RE_ItemClass>
+ </grg:containedItemClass>
+ <!-- Manager -->
+ <grg:manager>
+ <grg:RE_RegisterManager>
+ <grg:name>
+ </grg:name>
+ <grg:contact>
+ <gmd:CI_ResponsibleParty id="NASA_Contact">
+ <gmd:organisationName>
+ </gmd:organisationName>
+ <gmd:contactInfo>
+ <gmd:CI_Contact>
+ <gmd:onlineResource>
+ <gmd:linkage>
+ <gmd:URL>http://gcmd.gsfc.nasa.gov/Resources/valids/&lt;/gmd:URL&gt;
+ </gmd:linkage>
+ <gmd:protocol>
+ <gco:CharacterString>WWW:LINK-1.0-http--link</gco:CharacterString>
+ </gmd:protocol>
+ </gmd:onlineResource>
+ </gmd:CI_Contact>
+ </gmd:contactInfo>
+ <gmd:role>
+ <gmd:CI_RoleCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_RoleCode&quot; codeListValue="owner">owner</gmd:CI_RoleCode>
+ </gmd:role>
+ </gmd:CI_ResponsibleParty>
+ </grg:contact>
+ </grg:RE_RegisterManager>
+ </grg:manager>
+ <!-- codelist items -->
+ <xsl:apply-templates select="TOPIC"/>
+ </xsl:element>
+ </xsl:template>
+ <xsl:template mode="generalization" match="*">
+ <xsl:call-template name="lineage">
+ <xsl:with-param name="similarity" select="'generalization'"/>
+ </xsl:call-template>
+ </xsl:template>
+ <xsl:template mode="specialization" match="*">
+ <xsl:with-param name="similarity" select="'specialization'"/>
+ </xsl:template>
+ <xsl:template name="lineage">
+ <xsl:param name="similarity" select="'unknown'"/>
+ <xsl:variable name="id" select="generate-id()"/>
+ <grg:specificationLineage>
+ <grg:RE_Reference>
+ <grg:itemIdentifierAtSource>
+ <gco:CharacterString><xsl:value-of select="substring-after($id,'e')"/></gco:CharacterString>
+ </grg:itemIdentifierAtSource>
+ <grg:similarity>
+ <grg:RE_SimilarityToSource codeListValue="{$similarity}" codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#RE_SimilarityToSource&quot;/&gt;
+ </grg:similarity>
+ </grg:RE_Reference>
+ </grg:specificationLineage>
+ </xsl:template>
+ <xsl:template match="TOPIC">
+ <grg:containedItem>
+ <grg:RE_RegisterItem uuid="{$id}">
+ <grg:itemIdentifier>
+ <gco:Integer><xsl:value-of select="substring-after($id,'e')"/></gco:Integer>
+ </grg:itemIdentifier>
+ <grg:name>
+ <gco:CharacterString><xsl:value-of select="@value"/></gco:CharacterString>
+ </grg:name>
+ <xsl:call-template name="addStatic"/>
+ <xsl:apply-templates mode="specialization" select="TERM"/>
+ </grg:RE_RegisterItem>
+ </grg:containedItem>
+ <xsl:apply-templates select="TERM"/>
+ </xsl:template>
+ <xsl:template match="TERM">
+ <grg:name>
+ </grg:name>
+ <xsl:apply-templates mode="specialization" select="VARIABLE"/>
+ <xsl:apply-templates mode="generalization" select=".."/>
+ <xsl:apply-templates select="VARIABLE"/>
+ </xsl:template>
+ <xsl:template match="VARIABLE">
+ <grg:name>
+ <gco:CharacterString><xsl:value-of select="."/></gco:CharacterString>
+ </grg:name>
+ </xsl:template>
+ <xsl:template name="addStatic">
+ <grg:status>
+ <grg:RE_ItemStatus>valid</grg:RE_ItemStatus>
+ </grg:status>
+ <grg:dateAccepted>
+ </grg:dateAccepted>
+ <grg:definition gco:nilReason="missing"/>
+ <grg:itemClass xlink:href="#Item_Class"/>
+ </xsl:template>
+</xsl:stylesheet>
Added: schemaPlugins/trunk/iso19135/sample-data/nasa-gcmd-science-keywords-register.mef
(Binary files differ)
Property changes on: schemaPlugins/trunk/iso19135/sample-data/nasa-gcmd-science-keywords-register.mef
___________________________________________________________________
Added: svn:mime-type
  + application/octet-stream
This was sent by the SourceForge.net collaborative development platform, the world's largest Open Source development site.
This SF email is sponsosred by:
Try Windows Azure free for 90 days Click Here
http://p.sf.net/sfu/sfd2d-msazure
GeoNetwork-commit mailing list
GeoNetwork-commit@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geonetwork-commit
