[GeoNetwork-devel] Geonetwork / CSW 2.0
Hi andrea,
Thank for your answers.
But, I don't really understand how to use the interface of harvest management. The server to query has a adress as http://site.brgm.fr/ionicwrs/wrs/WRS (KVP binding).
What do you indicate in host : http://site.brgm.fr/ionicwrs/wrs/WRS ? Site.brgm.fr ? ...
Port --> 80
Servlet --> ??? WRS ?
Thank you for your help...
Pierre
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net [mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de Andrea Carboni
Envoyé : mardi 27 mars 2007 13:51
À : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Geonetwork / CSW 2.0
Hi Pierre,
GN has passed the CITE tests against the base CSW/2.0.1 spec.
This means that it can be queried to obtain metadata in the dublin core format.
The ISO 19115/19119 profile is implemented but it is based on an old draft which seems pretty different from the latest one.
I don't expect interoperability using the ISO profile.
The implemented operations are the mandatory ones:
   - getCapabilities
   - describeRecord
   - getRecords
   - getRecordByID
and you can use GET/POST/SOAP bindings.
Metadata affected by CSW queries are those in dc and iso19115/139 format. There are some stylesheets that convert these metadata into the proper dc output format.
I downloaded the last beta version of GN and I would like to try to
use the CSW 2.0 implementation with a connection betwwen GN and the
commercial product IONIC Catalog (to test ! ).
I studied the doc but I don't see how GN implements the CSW 2.0
standards. Some questions...
The CSW 2.0 describes these operations :
  - getCapabilities
  - describeRecord
  - getDomain
  - getRecords
  - getRecordByID
  - Transaction
  - Harvest
Does GN implement all ? Which binding is available (KVP, SOAP,....)
If I remember the last workshop, you decide to use the ISO 19115/19119
API profile. Do I mean that you transform each metadata file in GN in
a valide XML file according profile ? Do you integrate the 19119 schema ?
After, I will be able to start a "testbed" !
Pierre LAGARDE
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's Techsay panel and you'll get the chance to share your opinions on IT & business topics through brief surveys-and earn cash http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
GeoNetwork-devel mailing list
Le contenu de ce mél et de ses pièces jointes est destiné à l'usage exclusif du
(des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de ce
mél par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifié à l'émission du message. Il convient néanmoins de
vérifier l'absence de contamination à sa réception.
The contents of this email and any attachments are confidential. They are intended for
the named recipient(s) only. If you have received this email in error please notify the
system manager or the sender immediately and do not disclose the contents to
anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
content.
Hi Pierre,
I see a big misunderstanding here :slight_smile:
The CSW implementation is server side only at this point. No harvesting through CSW has been implemented yet. Harvesting setup through the management interface can only be done between GeoNetwork nodes for that reason. (The Web Accessible folder harvesting still needs some development.)
To use the CSW functionality of GeoNetwork one can use a CSW client. A test client is provided with the installer.
Harvesting through CSW is something that is still pending / open for someone to implement it.
Hope that helps resolve the issue.
Ciao,
Jeroen
On Mar 30, 2007, at 2:06 PM, Lagarde Pierre wrote:
Hi andrea,
Port --> 80
Pierre
Hi Pierre,
   - getCapabilities
   - describeRecord
   - getRecords
   - getRecordByID
  - getCapabilities
  - describeRecord
  - getDomain
  - getRecords
  - getRecordByID
  - Transaction
  - Harvest
Pierre LAGARDE
content.
