Has anyone created a tutorial or can anyone point me to <specific> steps on how to create a footer with GeoNetwork?
I see the posting made by Saher back in November regarding same topic and version 2.6, but I think I might be missing a step so it would help if I had a listing of all the files that need to be changed and how (not to mention a sample footer.xsl).
I'm working with version 2.8 at present if that helps.
Thanks in advance!
Kathy
El 05/08/2013 19:14, “Kathy Koch” <kkoch@anonymised.com> escribió:
Has anyone created a tutorial or can anyone point me to steps on how to create a footer with GeoNetwork?
I’m working with version 2.8 at present if that helps.
Hi
What user interface are you using?
Thanks in advance!
Kathy
Get your SQL database under version control now!
Version control is standard for application code, but databases havent
caught up. So what steps can you take to put your SQL databases under
version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
