[GeoNetwork-devel] geonetwork: Importing XML file
Hello,
I’ve downloaded the attached file from the website https://catalog.data.gov/dataset/surficial-geology-of-africa-geo7-2ag as an ISO19139 Metadata and tried to import it into my geocatalog based on Geonetwork 2.10.3 but the import operation failed due to the following error:
This was how I set my import window:
Could you support me importing that file.
Hamdi KACEM
Ingénieur Géomaticien
(attachments)
9816119b-4d30-4a54-a336-818b4c5a751b.xml (110 KB)
Hi Hamdi,
You didn’t select the right style sheet. Your metadata is not ISO 19115 format (you know, the first format that existed, with short tags)
If you have a look at your metadata content, it seems you would have to use the gmiTogmd style sheet (it uses gmi prefix instead of standard gmd prefix)
It tried, it works. Even if it doesn’t validate.
Jean
(attachments)
Le 16/12/2014 09:52, Hamdi KACEM a écrit :
Hello,
Hamdi KACEM
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
[http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk](http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk)
GeoNetwork-devel mailing list
[GeoNetwork-devel@lists.sourceforge.net](mailto:GeoNetwork-devel@anonymised.com.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geonetwork-devel](https://lists.sourceforge.net/lists/listinfo/geonetwork-devel)
GeoNetwork OpenSource is maintained at [http://sourceforge.net/projects/geonetwork](http://sourceforge.net/projects/geonetwork)
Jean Pommier – pi-Geosolutions
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
Hi Jean,
It definitely works with the gmitogmd style sheet.
Many thanks for your support !
Hamdi
De : Jean Pommier [mailto:jean.pommier@anonymised.com]
Envoyé : mardi 16 décembre 2014 12:45
À : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] geonetwork: Importing XML file
Hi Hamdi,
Jean
Hello,
Hamdi KACEM
[GeoNetwork-devel@anonymised.comts.sourceforge.net](mailto:GeoNetwork-devel@lists.sourceforge.net)
