[GeoNetwork-devel] Geonetwork metadata layout view
Hi there
Is it possible to edit the order that the various elements are displayed for
a metadata record ?
eg. 'Identification info' , 'Point of contact' etc.
Example result that I'd like to change is attached.
http://osgeo-org.1803224.n2.nabble.com/file/n6429579/GN_metadata.PNG GN
thanks,
Josh
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geonetwork-metadata-layout-view-tp6429579p6429579.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
The quick answer is that yes it is possible to edit the order in which the
metadata elements are displayed. However, the solution I would give involves
manually editing some .csw files. For instance the example in your
attachment would have been generated from the xml using metadata-show.xsl or
metadata-show-embedded.xml. Editing these files would give the result you
want.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geonetwork-metadata-layout-view-tp6429579p6429622.html
